Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 11-03-2005, 06:07 PM
jennings41 jennings41 is offline
Question 1987 olds 98 stalls after driving 15-20 min.
i have been having trouble with a 1987 olds 98 stalling after driving 15 min. or once it heats up. seems to run fine then bucks and stalls. it will start back up 5 min. later and seem to be fine but will repeat. i have replaced plugs and wires, oxygen sensor, ignition coil, ignition control module and mass air flow sensor. i just don't get it. can anyone help? thanks grant in san diego 858.395.6058
Old 11-03-2005, 06:37 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1987 olds 98 stalls after driving 15-20 min.
Replace the crank position sensor and the problem should go away. Location depends on engine size.
Old 11-03-2005, 06:39 PM
maxwedge maxwedge is offline
A990 racer
Sounds like the classic crank sensor symptoms, but you should try and get a scanner on it when this occurs and check for cranking rpms, if none the cks will probably fix it. Do a search on this site for a sensor check with a dvom, there are a couple of good posts on this.
Old 12-20-2005, 03:38 PM
Matthew53 Matthew53 is offline
Re: Re: 1987 olds 98 stalls after driving 15-20 min.
I'm having a similar (if not identical) problem with my 1992 98 Regency. It started as a simple power loss on upward grades and right turns, and progressed to problems starting if the nose is pointing downhill. Now, it seems like I can drive without trouble on the top half of a tank of gas, but on the bottom half get stalls and sputtering (acting just like a vapor lock, but it's fuel injected). When you let it sit for about five minutes, it starts right back up as if nothing happened. I've been wondering if there might not be a problem with the fuel filter, because it happens more as the gas level nears the bottom...
If it's the crank position sensor, I have questions:
Is this something a relative neophyte could replace?
If not, would anyone know about how many labor hours replacement should take?
Is the CPS itself an expensive part?
