Old 11-03-2005, 04:32 PM
enforcer GT enforcer GT is offline
Brakes
Well, i have a 2000 GP GT and usually my brakes (i think its my brakes) squeek, its not a constant squeek, but like a squeek squeek squeek,lol. this usually havens after i accellerate fast (which i do just about every time i drive so mabye it is just after they heat up). But the problem is it only squeeks when im not applying the brakes, when i hit the brakes the squeeking goes away. So, do i just need to replace the pads, or do i need an allignment or something? Oh, and any suggestions on pads, is there really any diffrence? THANKS.
Old 11-03-2005, 04:40 PM
Madmunky Madmunky is offline
Send a message via MSN to Madmunky
Re: Brakes
Sounds to me like the pads could be low, just pull the tire and visually check them out and see how much is left. I tend to check mine whenever I have the tires off...
When it comes to buying new pads, I was told I should try and find a performance pad. I'm looking for something that doesn't give off as much break dust, my shiney rims turn black the first time I take it out after a wash.
1995 Pontiac Grand Prix GTP
3.4L DOHC
only mods are aesthetic, for now
My Cardomain Page
Old 11-03-2005, 05:17 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Brakes
The squeak you hear is probably the wear sensor. That's why you hear it when the brakes are released, and don't when the brakes are applied. Try a quality set of Ceramic pads (AC-Delco Durastops or Bendix), they don't cover your wheels with black dust, and are virtually squeak free.
Old 11-03-2005, 07:09 PM
regalfriend regalfriend is offline
Re: Brakes
Like Rich said its the wear indicators...the reason it is not a constant sqeak is probobly because your rotors are slightly warped and need to be cut or replaced....For your car ceramic pads are the best--no black dust, better braking, and more miles...Alot of shops wont use ceramic pads because they cost more for the part. Also a cheaper pad will wear faster and you will be back to them sooner to get brakes done again.
Old 11-03-2005, 10:24 PM
Thanks. im off to autozone tomarrow to get ceramic brake pads. ill keep ya posted on the results
Old 11-04-2005, 08:21 AM
Langning Langning is offline
I would replace both the pads & rotors since the parts are cheap enough. I got a set of 4 E-bay rotors & pads shipped to my house for $150. I am quiet happy with them. If I do it again, I will pay more for the rotors with anti-rust coating...
Old 11-04-2005, 10:02 AM
richtazz's Avatar
Re: Brakes
Make sure you lubricate the slide bolts, and torque the lug nuts by hand with a torque wrench. Doing so will eliminate uneven pad wear and reduce the chance of rotor warpage/distortion due to uneven clamping forces from unevenly torqued lug nuts.
