Old 11-03-2005, 03:06 PM
ulremember ulremember is offline
V6 3.4 Camaro ICV
Hello to all.
I have a question about a 1990 (I believe) 3.4 Camaros Idle Compensating Valve/Solenoid.
I have replaced the ICV twice due to a very high idle- around 2000-3000 rpms. Prior to changing the valve, if the ignition was shut of and restarted, the idle would hold for a while. It is still doing it with the new ones. Someone suggested that we oil the new one. I suspect that it could be the computer. I had inspected a older Camaros fuel pump and found that it was receiving only 5 volts. The computer was replaced and the problem was solved.
Is it possible that the computer is sending or not sending the proper signal to the valve.
Any suggestions are welcomed.
Thank you in advance.
Chuckster
Old 11-03-2005, 03:54 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: V6 3.4 Camaro ICV
The 3.4 V6 wasn't in a 1990, it's either a 1990 with a smaller V6 or a 1993+ camaro.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 11-03-2005, 04:38 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Well if it's a 1990 and you have a valve for a 3.4 than that's a problem... same thing for if it's a 3.4 and you got a valve for a 1990
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-07-2005, 10:57 AM
Re: Re: V6 3.4 Camaro ICV
You are right. It is a 1995 Camaro. Any ideas?
Old 11-07-2005, 12:33 PM
Maybe try the throttle position sensor?
2006 Hyundai Sonata
Old 11-08-2005, 11:20 AM
We changed the TPS first. Has anyone heard aboout faulty ECM's?
Chuckster
Old 11-08-2005, 04:04 PM
I've heard of them, not too much much about people having them go out on them...
2006 Hyundai Sonata
Old 11-09-2005, 01:26 AM
95, plug in the OBD scanner (not sure if you have OBDI or OBDII) and see if it turns up any codes (not all codes set the SES light)
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
Old 11-09-2005, 10:58 AM
Thanks for the replies!
Chuckster
Old 03-26-2006, 06:18 PM
buddy-2k buddy-2k is offline
Originally Posted by ulremember
Hello to all.
Chuckster
hay urlremember if you have a 3.4 chevy v6 and are having trouble with the idle air control you need to do the following when installing a new one , the directions that come with it should say that after installing it you need to start the car and let it get up to nornal operating temperature at a road speed of 40mph. at 40 mph the ecm will will command the iacv pintle to fully extend to the mating seat. this allows the ecm to establish an accurate reference to the pintle position . and proper idle regulation should now result
Old 03-26-2006, 10:20 PM
Hey Buddy welcome to the boards, but don't bring up old threads like this. If you have something new to say create a new thread, and if neccesary link to it...
2006 Hyundai Sonata
