Old 11-03-2005, 02:45 PM
Law_3KGT Law_3KGT is offline
what oil?
ok i have that freakin lifter tick and its driving me crazy! one mechanic told me to go with a thicker oil and another said thinner. they are both reliable so far so i don't know who to believe. so which is it thinner or thicker? btw i read the FAQ and i don't have enough cash to get the lifters replaced.
Old 11-03-2005, 03:20 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: what oil?
I've heard switch to some lighter oil and drive the piss outta your car for 5-600 miles... then switch and go heavier... the lighter will help get the dirt and gunk from all the little corners and crevices and the thick should help with the rest...
Then again, I was told to make sure you have enough oil, and make sure it's not the injectors... as mine "pulse" really loud... and that's what my lifter tick turned out to be...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-03-2005, 04:19 PM
Re: what oil?
yeah my oil level has been fine. i just got an oil change from 30w to 10-40 and put some of that lucas stuff in it too. the tick was really bad before the change and then after it steadily started to fade but is still there. i called one of my mechanics and told him about it and he said i should get the 10-40 out and put in a lighter oil. but earlier my other mechanic said to go heavy so thats where i'm at now. thanks for the advice i'm starting to lean towards the thinner stuff now. anyone else got info?
Old 11-03-2005, 04:29 PM
Re: what oil?
oh yeah and he said it was a dirty lifter i'm guessing thats correct but if not let me know.
Old 11-03-2005, 05:27 PM
Igovert500's Avatar
blue + red light magnet
Re: what oil?
Well older dirtier oil does contribute to it, but hte underlying factor is that our stock lifters (pre-99) have entirely too small holes for hte oil to go through (1mm compared to the later 3mm) So thicker/dirtier oil increases audible ticking.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-04-2005, 01:43 PM
Re: what oil?
thanks a lot. one more thing though. in the FAQ its says something about switching to 3rd gen. lifters. so i can change out my old ones for 3rd gens without any problems?
Old 11-05-2005, 12:40 PM
Igovert500's Avatar
Re: what oil?
I believe they are the same for all the DOHC 3S engines, so yes you can replace them without any problems. They run around $250-350 if I remember correctly. Check out the sites listed in that section of hte FAQ, and check out IPO's site too to find the best pricing.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-05-2005, 01:04 PM
3000-G_T_S_L 3000-G_T_S_L is offline
Send a message via AIM to 3000-G_T_S_L
I have a 99 with the lifter tick, and after trying all the diff weights of oil someone finally said to try switching to synthetic, "run the piss" out of it for the 1st 500 or so miles, and change it. Well it worked for the most part, when it's time to change the oil again it comes back ever so slightly, and now I'm in the synthetic oil tree, it would be foolish of me to switch back. Guy told me synthetic runs cleaner longer, somethin like that. Well, good luck.
1999 Pearl White 3000GT SL - Sold
1992 Dark Green 3000GT VR4 - Spun Bearing
2006 Black Suzuki Katana 600cc -hit from behind, totaled
*JUST BOUGHT*2008 Red Mitsubishi Lancer ES - planning
Old 11-07-2005, 07:38 AM
Mikelb's Avatar
Re: what oil?
Synthetic is much better.... but much more expensive... if you can afford it, I'd say it's worth it...
