Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 11-03-2005, 01:41 PM
keryart keryart is offline
1998 Dodge Intrepid Starting Problem
1998 Dodge Intrepid Starting Problem:
When I try to start my Intrepid, I hear a single click and no start. Sometimes, it finally starts; sometimes it doesn't.
I have taken the car to my Dodge dealer (twice) and it always starts for them. They have checked the system without finding any problems. The dealer mechanic says that he has checked all elements of the system, including connections. He says the problem is either with the starter or the ignition, but none of us wants to replace parts without determining the problem. They say they have tested both the starter and the ignition, and both test OK. They have no other ideas without seeing the problem occur with them.
Note: I replaced the battery, cable and plugs during normal maintenance in June of this year (prior to having this problem).
Any suggestions on how I might proceed?
Old 11-03-2005, 09:54 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1998 Dodge Intrepid Starting Problem
starter solenoid is getting weak. Your best bet, if the battery cables are good, clean and tight and your grounds are good, clean & tight as well, is to replace your starter.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
