Old 11-03-2005, 01:26 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
Exclamation replacing injector, need tips
ok so the other thread came to the conclusion of changing my #3 injector. ive never done this before and i need some advice on
1. torque of upper intake bolts and is there a removal and install order?
2. do i need a gasket for the upp. intake?
3.do i have to remove the fuel lines/ throttle body do perform this job?
i have read tons of these threads but found not alot of mention to those things. and any other tips would be great.
btw 97 lumina 3.1 sfi
Old 11-03-2005, 04:46 PM
Goober
Re: replacing injector, need tips
ok well i have everything apart and the new injector is going in shortly. is there any other things i should check/do while this is apart?
Old 11-03-2005, 06:07 PM
wafrederick wafrederick is offline
Banned
The upper intake has to come off.If the gaskets come off intact,leave them alone.If the upper intake gaskets come apart in pieces,replace them.You can get the upper intake gaskets seprately at any auto parts store.The throttle body does not have to come off.the fuel lines do not have to come off.Put some grease on the injector o rings,they go in easy if you do this.
Old 11-03-2005, 06:34 PM
maxwedge maxwedge is offline
A990 racer
Use vasoline in the injector seals, lite coat.
Old 11-04-2005, 12:29 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The upper intake plenum gaskets are really cheap($5-$8), so replace them regardless. I would replace all of the injector seals, at least the lowers when you pull the rail off, leaking raw fuel is a fire hazard, and the o-ring kit isn't that expensive either ($15)
Old 11-05-2005, 11:01 AM
Goober
got the upper plenum gasket for 3.99 and the egr gasket for 1.99. now today im putting this all back together. uuuuuuughh
Old 11-07-2005, 04:40 PM
dennisinmo dennisinmo is offline
Re: Re: replacing injector, need tips
You probably already have this put together but one tip I learned the hard way was to pressurize the fuel rail after you have installed the injectors and before you install the upper intake. You can check for leaks and not have to remove the upper intake again. Be careful watching for fuel when pressurizing the rail. Don't get it on you. Good luck.
Old 11-07-2005, 09:49 PM
Goober
yes i did it on saturday and sure enuff, the fuel line was leaking so i made a ghetto wrench to tighten it but it didnt werk so i tore it back apart today and the o ring on the fuel line was ripped, i never knew it was even there when i took the fuel rail off because it came off inside the fuel rail. and dumb oreillys say they dont carry that o-ring so im screwed unless autozone has it
