Old 11-03-2005, 01:22 PM
bill57 bill57 is offline
2004.5 2500 Lift
i have a 2004.5 duramax and i am wondering if i get a 3 inch body lift and crank up the torsion bars can i fit 35's under it?
Old 11-03-2005, 02:49 PM
grindking134 grindking134 is offline
Re: 2004.5 2500 Lift
IDK I think you would have some major rubing issues with your front tires when you turn. Thats if you can even get them on
Old 11-03-2005, 06:41 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
I've got 33's without the body lift, so you might pull it off. Not a big fan on the big body lifts though.
Old 11-03-2005, 08:35 PM
Moose is loose Moose is loose is offline
Since the 2500's sit higher naturally, you should be able to fit 35's (or 315's) under it with 3" of lift. The major problems with a GM truck is the width of the fenderwell. At even 3/4 turn, you encounter serious rub. The front lower fascia is easily trimmed, but those tight fenderwells aren't so easy. IMO, you should be able to fit 35's under it with the right backspacing, a 3" lift, and cranking the bars about 4 turns. As far as the rear is concerned, no probs with a 3" lift and either a 1" block or add-a-leafs.
Old 11-03-2005, 08:51 PM
airjam18 airjam18 is offline
I've seen a couple of guys on GmFullsize.com that are running 35's on stock Dmax's. They only cranked the torsion bars a bit. With a 3" body I think you could definitely fit 35's but you could probably do it stock. There's a guy named TwoTone over there that has a stock Dmax w/ some 35's on it. You may wanna see how much he rubs, if at all.
Old 11-04-2005, 09:22 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I'm against body lifts all together. If you want to fit 35's the right way, get a 4" susp. lift.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 11-04-2005, 09:44 AM
Re: Re: 2004.5 2500 Lift
I agree. Especially if your 2500 is an HD series...they already hang a lot of frame under the rockers.
