Old 11-03-2005, 02:07 PM
86parky 86parky is offline
Washer Pump Motor
86 Park Ave. Pump For Windshield Washer Isn't Working. Looks Like Both Pump And Wiper Motor Are Built In Together.
Old 11-03-2005, 05:52 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Washer Pump Motor
The pump has a clip holding it in the motor housing. Slide the clips back and pull down on the washer motor to remove. Sometimes you have to use a persuader.
Old 11-06-2005, 02:59 PM
Re: Re: Washer Pump Motor
[quote=HotZ28]The pump has a clip holding it in the motor housing. Slide the clips back and pull down on the washer motor to remove. Sometimes you have to use a persuader.[/QUOTE
Thanks HotZ28, I will look into that today. I'll let you how it went.
Old 11-06-2005, 03:10 PM
Re: Re: Re: Washer Pump Motor
Thanks again HotZ28, I broke the plastic housing by clip,
but was able to get pump out.
Old 11-06-2005, 04:06 PM
HotZ28's Avatar
AF Moderator Elite
Glad to here you got the pump out. Be sure to blow out all the washer hoses and clean the screen on the pickup tube in the fluid reservoir prior to installing new pump. If the new pump needs something to hold it in place, try a little silicone on the body prior to sliding it in the housing.
Put a piece of duct tape or rubber bands on it to hold in place until the silicone dries. Good luck!
Old 11-06-2005, 04:12 PM
Gocart879 Gocart879 is offline
where is the sensor for the idiot light located?
Old 11-07-2005, 02:02 AM
HotZ28's Avatar
AF Moderator Elite
In the washer fluid reservoir.
