Old 11-03-2005, 12:16 PM
chief_engineer_05 chief_engineer_05 is offline
voltage problem
I have a 97 escort. i have bought a new battery and altenater . when i start the car it runs fine, but when i let it sit for a couple of hours the battery is dead. i put a volt meter on the battery and i can see it drop in voltage while the car is off.. i have don't everything i can to figure out what could be pulling a drain on it.. can someone help me out .. need to know where to start? thanks
Old 11-03-2005, 05:02 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Buy a test light. Disconnect the positive battery cable. Hook up the test light between the battery post and battery clamp. If the light is on then you have drain somewhere. One at a time pull your fuses out. When you pull out a fuse that makes the test light go out then that is the circuit draining your battery.
Nevada Tumbleweed
Old 11-03-2005, 06:44 PM
Re: voltage problem
okay i will try that out
Old 11-03-2005, 08:57 PM
Re: voltage problem
okay i found that the fuse for the fuel inj. is the one causing it.. what would be your suggestion on this?
Old 11-13-2005, 07:34 PM
jaksdad66's Avatar
jaksdad66 jaksdad66 is offline
Re: Re: voltage problem
I have a 96 1.9L with the exact same problem as above. Anyone have any more ideas?
Old 11-14-2005, 04:57 AM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
there was a post just recently with the same problem it turned to be within the wire harness or plug where the plug goes to the fuel rail. ( I think).
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 11-14-2005, 04:18 PM
jaksdad66's Avatar
Re: Re: Re: voltage problem
After more investigating with my newly purchased haynes manual, I found that when I unplug the altenator the short goes away--Possibly shorted diodes in inside.
Old 11-14-2005, 07:17 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: voltage problem
chief, it sounds like your describing a stuck fuel pump relay, causing the pump to run constantly. With the test light still connected and fuel inj. fuse reconnected, locate the fuel pump relay and switch it with another relay.
