Old 11-03-2005, 10:32 AM
davydawg davydawg is offline
Send a message via AIM to davydawg Send a message via MSN to davydawg
help did a boo boo
i just changed my tranny filter and was refilling my tranny. I put about 3 quarts in and grabbed for the forth and started to pour and Doh! it wasnt red, it was freaking oil i only poured little in and stopped. So what u guys think?? will it be fine or should i change again?????
Old 11-03-2005, 10:46 AM
Allbert Allbert is offline
Re: help did a boo boo
If it were my truck and I'd only put in a half quart or so, I'd probably drive it around for a few miles and see if there were any noticeable difference in shift performance. If there were none, I'd just wait until the next scheduled oil change and then do the normal drain and refill. Engine oil and transmission oil are pretty different as far as viscosity and friction properties, but I don't think a little 5w30 mixed with a lot of Dexron III is going to change trans performance much, if any. If the peace of mind is worth more than a few quarts of Dexron III though, you could always just drain out what you've poured in and start over.
Old 11-03-2005, 11:12 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: help did a boo boo
That is what I'd do. I'd be afraid the detergents in the oil would contaminate the ATF. Plus the fact that the oil is multiviscosity, is heavier than ATF, the extra strain (no matter how small) could damage something.
Old 11-03-2005, 11:28 AM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
How much is a little?
How much does 3 quarts of trans fluid cost?
Trans fluid I think is like hydraulic fluid, which doesnt like to be contaminated. Granted you are talking about some small amount.
I would suggest looking into what happens to engine oil when mixed with trans fluid. Also what happens to trans fluid when it is exposed to oil.
These are two pretty different substances.
Talk to some old mechanic guys. Im sure its happened before.
Old 11-03-2005, 12:16 PM
it wasnt much oil, about a shot glass no more then a 1/4 of a cup
Old 11-03-2005, 12:40 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
I wouldn't take the chance. Just drain it out and start all over again with fresh filter and ATF. Oil is to heavy for the hydraulic system of the trans. You'll definitely regret it later when the valve body of your trans clog’s and something burns out.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
