Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 11-03-2005, 09:36 AM
gcurry gcurry is offline
clutch pedal, leaking inside vehicle
I have (what I'm guessing is hydraulic fluid) leaking from the pinion behind my clutch pedal, it runs down the pedal and into the pedal cover and onto the floor mat below. What part is malfunctioning, how can I fix it?
Old 11-06-2005, 01:19 PM
~manuel~ ~manuel~ is offline
Re: clutch pedal, leaking inside vehicle
that would be the clutch master cylinder.if it is leaking it will have to be replaced. i suggest you purchase a haynes manual to guide you through it and it also shows you how to bleed the clutch afterwards.
