Old 11-02-2005, 11:44 PM
3kgt222's Avatar
3kgt222 3kgt222 is offline
Loud Noise?
When I frist bought my car there was already a weird noise when every time I would start the car it would make a loud noise like eeerrkkkk!!.., then it gone, the owner said i need a new starter, but i never change it because i bought a new batteries like in the first week and the sound went away. So now it back, and i dont like it... do i need a new starter or is it something else, please help me out guys
Old 11-02-2005, 11:50 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: Loud Noise?
It most likely is your starter - sounds like the sound of a weak starter to me, the reason it would have went away is because - when u installed a brand new battery the starter was gettin alot more cranking amps an was not being strained as it used to be with a weaker battery - so yes find a new starter.
Matt
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 11-03-2005, 12:36 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Loud Noise?
get a new starter? heck, why not just rebuild your current starter! they're pretty simple. i rebuilt my dad's starter on his 96 camry. it would be fun and you'd get dirty, and could call yourself a grease monkey and a gear head. why not find out why the starter isn't performing up to par? i bet the rebuild could tell you. hint: its probably corroded electrical connections that could be cleaned or simply replaced for a nominal fee.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-03-2005, 01:09 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: Loud Noise?
It is most likely a sticking gear. I'll be damned if I cant remember what its called. It really has nothing to do with the electrical part of it. Its more of a mechanical failure and it happens on alot of 3s starters.
Old 11-03-2005, 11:51 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: Loud Noise?
Check ebay....
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-03-2005, 01:29 PM
3kgt222's Avatar
Re: Loud Noise?
lol but no, i dont think i want to buy it on ebay,thank guys, i always kind of knew it was the starter, for sure next week or so am going to replace a new starter or as soon as possible cause driving around like this is embarrassing, it like my car is crying
Old 11-03-2005, 01:47 PM
Mikelb's Avatar
Re: Loud Noise?
lol, it was just a suggestion... I get new parts up there all the time, usually way below retail and/or what I can get it for locally...
local shop charges a/b $450 for a Fidanza Lightweight Flywheel... got one on ebay $365 delivered to my door... already had tranny pulled, so I'm putting it in myself...
Old 11-03-2005, 02:43 PM
Igovert500's Avatar
blue + red light magnet
Re: Re: Loud Noise?
nice find. I know IPO sells it for $360, but that difference is nominal. Everywhere else I've seen it for is $400+ Let us know how you like it when you get it installed and running.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-03-2005, 03:07 PM
Mikelb's Avatar
Re: Loud Noise?
Oh definitely... waiting on the dealer to get the roll pins, so I can put it all back together... I'll keep ya posted...
Old 11-03-2005, 03:09 PM
Mikelb's Avatar
Re: Loud Noise?
About the starter, I was thinking... I had a friend who's starter completely locked up and stopped functioning... he simply beat it with a pipe wrench... it knocked loose the dirt and what-not... it lasted him another couple of months... is there a solenoid that might be hanging up?
