Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-02-2005, 11:39 PM
ContourChic ContourChic is offline
Unhappy Broken cam/timing chain and I need a new engine???
I sent my 1998 Ford Contour SE to the dealership that I purchased it at. I also purchased a Powertrain Care warranty which would cover internal engine parts and transmission (drivetrain). It has been a week since they have had my car. Today I heard that my cam/timing chain (not sure which one but it is a chain of some sort) was off and damaged the heads in the engine. I was told that I need a new engine and that it would not all be covered by warranty. I bought the car used at 46k miles. The carfax history report was clean. The car now has 81k miles and has been subject to all routine services. Does this sound right or am I getting screwed? PLEASE let me know because I do not have the money nor the time to deal with the dealers BS.
Old 11-02-2005, 11:56 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Broken cam/timing chain and I need a new engine???
I4 or V6?
i know v6 has chain but sometime people gets mixed up
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-03-2005, 07:11 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
if indeed your timing chain failed, this would be the first instance ive heard of this happening in the 6 years ive been part of contour.org. NOBODY over there has ever had that happened. I think its unlikely that it failed. I would say its damn near impossible for the chain to skip on the sprocket. Anyways, if 2.5L V6 is toast, I would highly recommend a 3.0L swap.
Check out the 3.0L forum over on www.contour.org. Tons of info there on how to swap it and other valuable info.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-15-2005, 12:33 AM
Re: Re: Broken cam/timing chain and I need a new engine???
Yeah, it is a V6 2.5L
Originally Posted by sk8ter_in_ny
I4 or V6?
Old 11-15-2005, 12:39 AM
Well, then that sounds like just my luck. It was in fact the chain (I heard it clanking as the car idled). I'll inquire about the 3.0L and see how that would affect the price tag since the warranty will only cover my car's value ($3100) and the new engine with labor is ($5500). Thanks for the info!
Old 11-28-2005, 08:48 PM
ppg960's Avatar
ppg960 ppg960 is offline
Thumbs down Re: Re: Broken cam/timing chain and I need a new engine???
Read your warranty carefully. What is and not covered. That chain in a 2.5 V6 should never break. When a reputable dealership sells a used car, these types of items of checked closely before resale.
The heads in your motor are junk forsure.
Don't let the Dealer off the hook too easy here.
