Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-02-2005, 10:12 PM
atticus951 atticus951 is offline
pistons
Can you run 10:1 pistions on 93 octane? I had just bought some on ebay for like 250 with 1000 miles. I was just wondering before I had someone put them in.
Old 11-02-2005, 10:24 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: pistons
stock USDM GSR's have 10.2:1
You can run as high as 12.5:1, maybe more on premium.....it all comes down to tuning!!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-02-2005, 11:16 PM
Kven's Avatar
Kven Kven is offline
Re: Re: pistons
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 11-03-2005, 01:49 PM
Re: pistons
So that is a yes, witch way does compression work. Is 10:1 higher or is 13:1 higher. Thanks
Old 11-03-2005, 02:08 PM
Schister66's Avatar
AF -Advisor
Re: pistons
13:1 is higher
That means that if you have 13 cubic inches of air for example, it is compressed into one cubic inch
Old 11-03-2005, 06:12 PM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
Actaully, the GSR has a stock compression ratio of 10.0:1. The USDM B16A had a 10.2:1 c/r though, and so did the 1st gen jdm B16a and the European B16A1.
The B18C1 had a stock c/r of 10.0:1. There was a B18C4 in Europe, this was the same as the B18C1. It came in a 1.8 civic. The displacement is 1797cc. It has a power output of 170hp @7600rpm and 128ft-lbs @6200rpm. 10.0:1 c/r. 8100rpm redline. Came both OBD-I and OBD-II.
The USDM B16A2/3 has a 10.2:1 c/r. The B16A2 came in the OBD-II Del Sol Vtec and came in the 99-00 Civic Si. The B16A3 came in the OBD-I Del Sol Vtec. 1595cc. It has a power output of 160hp @7600 and 111ft-lbs of torque @ 7000rpm. 10.2:1 c/r. This motor was OBD-I and OBD-II. Rod-Stroke ratio of 1.74.
The 1st Gen JDM B16A/ European B16A1 also had a 10.2:1 c/r. This motor is same output for both jdm and europena. It either came in an 88-91 JDM car (B16A) or a 1.6/Vti in Europe (B16A1). 1595cc. It has a power output of 158hp @7600 and 111ft-lbs of torque @ 7000rpm. 10.2:1 c/r. This is a non-OBD motor. Rod-Stroke ratio of 1.74.
The 2nd Gen JDM B16A, from 92+ JDM cars, has a 10.4:1 c/r. 1595cc. It has a power output of 168hp @7800 and 116 ft-lbs of torque @ 7300 RPM. 10.4:1 c/r. 8500 rpm redline. Came OBD-I and OBD-II. Rod-Stroke ratio of 1.74.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 11-03-2005, 06:13 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: pistons
well i'll be damned
I always thought GSR was 10.2:1 myself!
Awesome post eckoman do somthing like this for ls1s?
Old 11-04-2005, 03:21 PM
Re: pistons
Thanks alot for all this!
Old 11-04-2005, 04:48 PM
Honda God
Re: Re: pistons
No Problem. We're always glad to help. That's what we're here for.
EPR Member 4 Life
