Old 11-02-2005, 08:03 PM
drewallen42 drewallen42 is offline
Engine Cooling Fan Question for female
I have a 94 Metro. The radiator cooling fan isn't coming on and the car is starting to overheat. I don't know much about cars but have the Haynes manual. It said to check the fuses (i looked under the dash and all fuses look good). It said to unplug the connector and use wires to hook up to the battery. (i did and the fan came on) It says if the fan works it's then its the temp switch, fan relay, or the harness. How do I test these 3 things, and which is it most likely to be? Like I said I don't know a whole lot about this so the more specific the better. Thanks.
Old 11-03-2005, 07:51 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Engine Cooling Fan Question for female
its the sensor you jumped across, since the fan came on the relay and fan are fine so just replace sensor
Old 11-04-2005, 11:16 AM
When you say sensor what do you mean? Thanks for helping.
Old 11-04-2005, 01:15 PM
Crvett69's Avatar
the item you unplugged the wire from to use a jumper wire
Old 11-04-2005, 10:38 PM
The thing I unplugged is attached to the fan motor. Can you replace that whole cord? It doesn't look like it can just be replaced. If the sensor is the part that goes into the thermostat housing then that's been replaced. Also since you've been so helpful, which way is the fan supposed to blow air? From the outside in, or the inside out? I'm thinking of running a switch into the dash. I don't want this thing to overheat.
Old 11-05-2005, 04:00 PM
Crvett69's Avatar
if you short across the one going to fan motor it should blow the fuse. unplug the wire going to the sensor on the thermostat housing with the 2 wire plug. not the single wire. try jumping across it. the fan should blow from outside in or if it came on while you were going forward and it blew from inside out it wouldn;t move any air
