Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '01-'05 Civic
Old 11-02-2005, 07:36 PM
gmcuajo gmcuajo is offline
D17A1-A2 Engine Dimensions?
Does anyone know the dimensions of the D17A1-A2 engine?
01+ civic engine
Cylinder Head:
*Intake Valve Diameter
*Exhaust Valve Diameter
*Intake Stem Diameter
*Exhaust Stem Diameter
*Intake Installed Height
*Exhaust Installed Height
*Intake Valve Total Length
*Exhaust Valve Total Length
*Combustion Chamber Volume
Piston:
*Wrist Pin Diameter
*Dish Size
*Dish Volume
*Compression Height
*Total Height
*Bore Diameter
*Deck Height
*Rod Length
Old 11-05-2005, 05:44 PM
Re: D17A1-A2 Engine Dimensions?
I found some and will share with you:
Cylinder Head:
*Combustion Chamber Volume= 35.80cc
*Gasket thinckness=0.026
Piston: (D17A2)
*Wrist Pin Diameter= 19mm
*Dish Size= 2.66mm
*Dish Volume= -6.20
*Compression Height= 27mm
*Total Height= 46.50mm
*Bore Diameter= 75mm
*Deck Height=212mm
*Rod Length= 137mm
