Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-02-2005, 08:32 PM
billyo69 billyo69 is offline
Flickering headlights
Does anyone know what causes the head lites to flicker? Also dash lites and interior lites
Old 11-03-2005, 12:14 AM
Shadetreeme's Avatar
Shadetreeme Shadetreeme is offline
If you have a system with a big amp drainning power. (Disco lights) that is the prob. Or if you don't I would say your alternator is not charging your battery.
2002 Impala 3.8 Type II LS, NAIOA's first prototype FWI 7" K&N cone/U bend delete/AC Delco rapid fIre plat plugs/Borg-Warner perf wires/180*Tstat/Armor Mark serp/Meguiar's polishing system
Old 11-03-2005, 10:39 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: Flickering headlights
there is apost about this already, you can do a search on it, I dont remember what it ended up being, but I think it was the DRL sensor. but just do a search and you should find it.
Old 11-04-2005, 12:37 AM
micali micali is offline
The BCM had to be repalced. You can do it yourself but then the car won't start after the new one is installed. It will need to be programed. I've been told the BCM is not expensive but it needs programmed afterwards.
Old 11-04-2005, 10:07 PM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Well i noticed the other day...when i switched my high beams on, then switched them back off, the drivers side headlight wouldn't come on for about five seconds...I did if a few times with the same results....I'm pretty sure it's not the bulb going bad. I tried hitting it a few times when it was parked trying to get it to flicker again with no results.....any ideas
mike
