Old 11-02-2005, 06:15 PM
rrruschman rrruschman is offline
91 tranny in 88 crx
put a 91 dx transmission in a 88 crx and the axles are different on the splines where it goes in the tranny does anyone know if i have to use different axles and if so will they go into the knuckle or hub or will I have to use different axles and knuckles together I have searched and not found anything specific to the 88 crx but found other years Please help.
Old 11-02-2005, 06:19 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: 91 tranny in 88 crx
is the crx an hf, dx, or si?
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 11-02-2005, 06:21 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
doesnt the 88 have diff splines than the 89-91 or is that just in the clutch and flywheel area?
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 11-02-2005, 06:29 PM
Shaguar47's Avatar
I think I have read somewhere on here that the 88 models and their flywheels or clutches are different than the 89-91 crowd. But it also depends on if his crx is an hf. If so, the hf axels won't fit in the dx tranny. He'd have to get new axels and hubs. Correct me if I'm wrong.
Old 11-02-2005, 08:26 PM
the crx had a 4speed in it but it is a 16valve engine so if it was a hf wouldnt that be a 8 valve engine still just trying to figure if I just try axles or axles and knuckles.
Old 11-03-2005, 08:16 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Never heard of a crx with a 4 speed tranny. I thought all HFs had 5-speed. Perhaps it was replaced with a Civic STD tranny which has different engine and tranny than hf but same size axles and hubs. Not sure...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-05-2005, 03:30 PM
Thanks guys apparently signals got mixed with the mechanic it was a 21 spline clutch disc that would not go on the tranny because the tranny has 20 spline so I asked him to use a 89 clutch kit on the car he said it would take a diiferent flywheel is that true? because I thought 88-89 flywheel same he says the pressure plate wont work Im stumped I think I will go to wrecking yard buy 90 flywheel and a new 90 clutch and just telling him good to go that should work right?
Old 11-05-2005, 03:35 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you tell him to buy all 90 parts like flywheel and the whole clutch setup, then yes it will work
Team Lonely Drivers
Old 11-05-2005, 03:47 PM
I think this site knows more about honda trannys than the transmission mechanic at the tranny shop I have he is very arguementive and says he knows it all but I dont think he works on enough honda trannies.
Old 11-06-2005, 03:21 AM
CrxFreak91 CrxFreak91 is offline
you need to find out if the tranny is a usa or canada model and that will help find out the spline ive had the same problem
