Old 11-02-2005, 05:54 PM
gonzo694 gonzo694 is offline
Send a message via Yahoo to gonzo694
Question Blower fan ticking???
I started my truck and as i did there was a ticking sound ..it wasnt from under the hood but under the dash and as i turned the fan up and down it shut off and turned on (ticking),,,then as i had the dial on heater and pressed the ciculation button it turned off for 10 seconds then ticked again ...it would do this for about 45 minutes then stop then start ..can anyone help????
Old 11-02-2005, 06:31 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Blower fan ticking???
There might be a peace of paper or somthing in your fan.
Old 11-02-2005, 07:13 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Piece of paper or possibly some leaves got in there. You would have to remove the blower motor assembly and take a look.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 11-02-2005, 08:22 PM
LongIslander26's Avatar
LongIslander26 LongIslander26 is offline
I've seen some of those squirrel cage fans crack right in the center, right where the motor shaft goes through it, and it makes the cage fan crooked, so it wobbles when it spins and sometimes you get that tick noise because it's touching the blower housing when it spins. Either way, you're going to have to pull the blower motor out and see. I've also seen alot of strange things get stuck in there. (Mice, leaves, pens and pencils, sticks.) Had one with an envelelope in it once with $11,000.00 CASH in it! Guy used to stash his money in a dash vent so his old lady wouldn't find it, and it fell into the blower.
ASE Certified Automotive Technician
ASE Certified Service Consultant
ASE Certified Parts Specialist
Employed at an Independent Shop
Vehicles:
2005 Silverado LS Crewcab 4X4
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
Old 11-02-2005, 09:44 PM
How do i remove the blower motor and is it a big job???????????????????/
Old 11-02-2005, 10:18 PM
Re: Re: Blower fan ticking???
Look under the dash where the glove box is, there are about 5 or 6 - 7 or 8mm screws holding it in. It's a little uncomfortable to get at, but its not terribly hard. The screws go in straight up from the bottom. Have at it and have fun!
Vehicles:
1979 GMC 4X4 Jimmy
1977 Chevrolet C20
