Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-02-2005, 05:01 PM
stryker9799 stryker9799 is offline
Exclamation front brakes???
I have a '91 olds cutlass calais that has the 2.5L in it, it has front disc brakes. Here is the problem. Driving down the road today, was braking to a stop, and heard what I guess I would describe as a clunking sound, it is quite loud.....it can only be felt/heard when braking. Also, noticed that there is a shimmy??(steering wheel goe back and forth left to right) while driving, you can see it do this. I am wondering if the problem is the lower ball joint or tie rod? Any suggestions? Thanks!
Old 11-03-2005, 07:12 PM
Mrbizness1 Mrbizness1 is offline
Re: front brakes???
I would think you might have a broken break pad or a bad cv axle joint.
A shimmy when stepping on the brakes usually means the rotors need to be cut or replaced depending on how thick they are. Clunking sounds are usually the axles.
Old 11-03-2005, 10:08 PM
found out what the noise was, apparently a bolt on the brake caliper was loose somehow, but fixed it. Still not sure what could make the steering wheel shimmy left to right(back and forth), could alignment be causing it or would it be something with the power steering ?
Old 11-04-2005, 03:42 PM
Re: front brakes???
Shimmies are most likely from tires out of balance, bent rims or poorly worn tires.
look at the tires to see if they are wearing evenly
