| Off-Topic Talk about anything other than cars. |
ecu part numbrs
im buying an ecu off of ebay and i need to know how to check the numbers that are on the front of the ecu. any help would be great
civics are for suckas 95' eclipse gst stock turbo new C.A.I. programmed ecu 2.0 DOHC manual greddy bov im workin on it. slowly but showly |
well
well is there anybody who can tell me if this is the part number
there are two sets of numbers that follow: module s/n TEN265881234 llllllllllllllllllllllllllllllllll (bar code) and chrysler p/n p04874156 04874 156 llllllllllllllllllllllllllllllllll which is the part number, is that what p/n stands for? any help is great
Re: ecu part numbrs
if u have a 95 eclipse, buy a 95 ecu... 96+ the plug is different...
i'm not sure about the part number... but someone told me it was the last 3 numbers, but i bought one that had different numbers,(my car is eclipse, i bought one from a Talon) and it still works great...so i think if the plug fits it will prolly work for you... |
Re: ecu part numbrs
ok, i now know where the part number is located!!, but i want to check to see if this part would fit my car, how do i do this using the pn, or where can i go to run these numbers.
Re: Re: ecu part numbrs
DSM geek |
I've posted this info in another thread sometime ago. Since I'm to lazy to find that thread, here's all the ECU part#'s your mind can handle
-Electronic control unit ('90) AWD w/Calif ECS - MD145902 - $1110.85 AWD w/o Calif ECS - MD145903 - $1110.85 FWD 2.0L Normally aspirated w/Calif ECS - MD128622 - $1040.11 FWD 2.0L Normally aspirated w/o Calif ECS - MD128624 - $1040.11 FWD 2.0L Turbocharged w/Calif ECS - MD128623 - $1040.11 FWD 2.0L Turbocharged w/o Calif ECS - MD128625 - $1040.11 1.8L SOHC w/Calif ECS - MD120845 - $973.00 1.8L SOHC w/o Calif ECS - MD128658 - $973.00 ('91 to '92) AWD auto trans w/Calif ECS - MD165532 - $914.00 AWD auto trans w/o Calif ECS - MD165531 - $1079.15 AWD manual trans w/Calif ECS - MD166263 - $1013.82 AWD manual trans w/o Calif ECS - MD166262 - $1013.82 FWD 2.0L Normally aspirated w/Calif ECS - MD166256 - $1013.82 FWD 2.0L Normally aspirated w/o Calif ECS - MD166255 - $1013.82 FWD 2.0L Turbocharged auto trans w/Calif ECS - MD165530 - $974.55 FWD 2.0L Turbocharged auto trans w/o Calif ECS - MD165529 - $1013.82 FWD 2.0L Turbocharged manual trans w/Calif ECS - MD166261 - $1013.82 FWD 2.0L Turbocharged manual trans w/o Calif ECS - MD166260 - $1013.82 1.8L SOHC w/Calif ECS - MD159562 - $977.54 1.8L SOHC w/o Calif ECS - MD159561 - $1238.05 ('93) AWD auto trans w/Calif ECS - MD193296 - $1028.52 AWD auto trans w/o Calif ECS - MD193300 - $993.49 AWD manual trans w/Calif ECS - MD193295 - $1028.52 AWD manual trans w/o Calif ECS - MD193299 - $1028.52 FWD 2.0L Normally aspirated w/Calif ECS - MD166256 - $1013.82 FWD 2.0L Normally aspirated w/o Calif ECS - MD166255 - $1013.82 FWD 2.0L Turbocharged auto trans w/Calif ECS - MD193294 - $974.02 FWD 2.0L Turbocharged auto trans w/o Calif ECS - MD193298 - $974.02 FWD 2.0L Turbocharged manual trans w/Calif ECS - MD193293 - $985.20 FWD 2.0L Turbocharged manual trans w/o Calif ECS - MD193297 - $1028.52 1.8L SOHC w/Calif ECS - MD159562 - $977.54 1.8L SOHC w/o Calif ECS - MD159561 - $1238.05 ('94) AWD auto trans w/Calif ECS - MD193296 - $1028.52 AWD auto trans w/o Calif ECS - MD304485 - $1051.38 AWD manual trans w/Calif ECS - MD193295 - $1028.52 AWD manual trans w/o Calif ECS - MD304484 - $1099.23 FWD 2.0L Normally aspirated w/Calif ECS - MD166256 - $1013.82 FWD 2.0L Normally aspirated w/o Calif ECS - MD304481 - $1110.22 FWD 2.0L Turbocharged auto trans w/Calif ECS - MD193294 - $974.02 FWD 2.0L Turbocharged auto trans w/o Calif ECS - MD304483 - $1072.42 FWD 2.0L Turbocharged manual trans w/Calif ECS - MD193293 - $985.20 FWD 2.0L Turbocharged manual trans w/o Calif ECS - MD304482 - $1083.14 1.8L SOHC w/Calif ECS - MD159562 - $977.54 1.8L SOHC w/o Calif ECS - MD159561 - $1238.05 ('95) 2.0L Normally Aspirated auto trans - MR4874192 - $498.75 2.0L Normally Aspirated manual trans w/Calif ECS - 05013112AA - $758.02 2.0L Normally Aspirated manual trans w/o Calif ECS - 05013113AA - $666.00 2.0L AWD Turbocharged - MD312464 - $816.00 2.0L FWD Turbocharged - MD309947 - $793.94 ('96) 2.0L Normally Aspirated auto trans - M04887050 - $639.00 2.0L Normally Aspirated manual trans - MR4887051 - $651.40 2.0L AWD Turbocharged - MD321911 - $840.42 2.0L FWD Turbocharged - MD321912 - $840.42 2.4L SOHC - MD326327 - $710.43 ('97) 2.0L Normally Aspirated auto trans - 05293014AC - $457.80 2.0L Normally Aspirated manual trans - 052593014AC - $457.80 2.0L AWD Turbocharged - MD326328 - $737.10 2.0L FWD Turbocharged - MD335287 - $737.10 2.4L SOHC - MD326327 - $710.43 ('98) 2.0L Normally Aspirated auto trans - 05293014AC - $457.80 2.0L Normally Aspirated manual trans - 052593013AC - $457.80 2.0L AWD Turbocharged - MD346676 - $573.02 2.0L FWD Turbocharged - MD346675 - $621.48 2.4L SOHC w/Calif ECS - MD339763 - $621.48 2.4L SOHC w/o Calif ECS - MD345713 - $615.57 ('99) 2.0L Normally Aspirated auto trans - 05269834AK - $740.13 2.0L Normally Aspirated manual trans - 05269833AK - $909.17 2.0L AWD Turbocharged - MD359403 - $800.20 2.0L FWD Turbocharged - MD359402 - $800.20 2.4L SOHC w/Calif ECS - MD359404 - $800.20 2.4L SOHC w/o Calif ECS - MD359405 - $806.40 If this doesn't help you out, it aint a DSM ECU
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister |
that helps
that helps in a sense, but im looking at a ecu that came from a neon(its for my n/t cousin) will it fit a 420A?< the p/n is different. it is P05289712 will it fit a 420a manny tranny n/t. or better yet how can i figure this out for myself, so i dont have to keep posting
