Old 11-02-2005, 02:23 PM
orion_X_100's Avatar
orion_X_100 orion_X_100 is offline
Send a message via AIM to orion_X_100
Manual Choke?
well, more problems with my car!
every morning(now that its like 40º-50º) my car struggles to stay alive! i have to practically floor it to keep the car going and it blows out a lot of gray smoke. . . . it takes like 5 minutes to warm up and run decently.
well since i gotta floor it everymorning, its wasting a lot of gas, and i doubt its very good to floor it when u first start it up in the morning.
aaannnyways, my question is: Will a manual choke solve this problem? How much? Is it easy to install? Or is there another solution for my dilema?
if not. . . i might sell it and buy the mk3 supra up the road
plz help me, Thanks
Old 11-02-2005, 03:54 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: Manual Choke?
Welcome ot the world of the carb. A choke will help if that is indeed the problem. Also sounds like you need some more pratice starting/driving a cold vehicle with a carb too. Chokes are VERY easy to install. You buy one, run the cable from the carb back to the dash/wherever you want it to be. Hook it up and away you go. Make SURE there are NO tight turns in it, if there is you will curse yourself later on.
Old 11-02-2005, 04:02 PM
Re: Manual Choke?
hmm, by tight turns, u mean no kinks in the cable or no tight turns when im driving it? and are they pretty cheap?(<$50?)
Old 11-02-2005, 04:15 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Manual Choke?
Actually there are some zero kink cables out there now and thery are pretty cool. My wife's little brother uses them for brake cables on his bmx bikes.
Anyways, this is going around the problem, you have an out of adjustment or non functioning choke pull off valve. We went over this when the car was having poblems before.
Make sure the choke plate is closed on cold start then slowly opening to eventually straight up.
Old 11-02-2005, 05:57 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Manual Choke?
Ok, On my car you have to push the pedal all the all down and hold it for like 2 seconds to engage the choke. I dunno if this helps because i have a 307 and it might be differnt from his (305?). After that it starts up and runs fine. I would check to see if the one on your carb if working or if there is one.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-02-2005, 09:12 PM
Re: Manual Choke?
nah, i dont got a 305, i got a 173(2.8l V6)
when i look at the choke plate before i start it up, it looks as closed as it can be.
anyway, after the car warms up, it runs perfect. . . so im guessing the choke works, but has something wrong with it!
about that choke pull off valve. . . how do i adjust it or make sure its working properly
Old 11-02-2005, 10:38 PM
wrightz28's Avatar
Re: Manual Choke?
pull offs are vacuum operated so if the hose is cracked or rotted it won't work right.
there should be an adjustment screw on it as well to set diaphragm pressure, to do it abolutely correct there is a protracter guage to moniter the precise operating angles. The hard part, every time you go to set it the engine must be stone cold, overnight set other wise you'll be chasing it for days.
Old 11-03-2005, 09:58 AM
Re: Manual Choke?
ok, ill try that. . . i told my dad that might have something to do with it and he was sooo sure you didnt have to adjust anything.
all the settings should be in a haynes manual right?
Old 11-03-2005, 10:08 AM
wrightz28's Avatar
Re: Manual Choke?
even better, go to autuzone.com and under products and how to it'll show ya.
