Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-02-2005, 01:45 PM
P.R._Ls/Vtec P.R._Ls/Vtec is offline
Cam gears adjusment
I bougth A pair of cam gears and I would like to know many degrees to give for a starting setting.
Old 11-02-2005, 03:34 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Cam gears adjusment
what are your mods? as for dailing in your settings, it needs to be done on a dyno with someone who knows how to dial them in. if not, just dial it in yourself until it feels right. there is no universal setting.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-03-2005, 04:19 PM
gomez268 gomez268 is offline
before you start advancing you timing and mess up your engine, most engines like having the intake advance 4 to 5 degrees and the exhaust 1 to 2. its better to do it at a dyno because you can advance the cam timing 2 degrees at a time until the power stops or drops, the same with the exhaust but in 1 degree increments but if it drops advance it instead. its best to do it at a dyno cause you affect the clearence of the pistons to valve if you advance or retard them to much and can cause some major problems.
