Old 11-02-2005, 12:37 PM
duffman667's Avatar
duffman667 duffman667 is offline
Send a message via AIM to duffman667
Power steering?
Lately when i have been driving my car I have noticed that the power steering fluid has been getting lower so no doubt its a leak. Sometimes the car is hard to turn and you hear the usual grinding sounds that a car with a faulty power steering pump has. None of that concerns me. I was wondering though what the hissing sound is that is comming from my steering column..its a constant hiss and I was wondering if that had anything to do with the power steering pump or rack or what. Any advice would be appreciated. thank you.
Old 11-02-2005, 09:53 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Power steering?
can you describe the hissing sound a bit more? does it occur all the time? or only when turning? do you think it is at all related to the pwr steering? you might check the tension in your pwr steering belt.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
