Old 11-02-2005, 12:28 PM
Wick001 Wick001 is offline
Guy's I know this is the Blazer forum, but you guys know what your talking about...
I have a 1997 Mustang GT 5-speed with 40k miles, after i start the car, it makes this awful clanking/ticking noise for like 2 seconds then stops and idles/runs great, there is only 40k miles on it. It will stop doing this when the car is fully warmed up. It started doing this one morning while in an angry mood, i had just started the car and did a small burnout, ever since then it has made this noise after it starts. to me the noise sounds like its coming from inside the engine...Any ideas guys?
Old 11-02-2005, 01:17 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Re: Guy's I know this is the Blazer forum, but you guys know what your talking about...
Well the biggest problem you have is it's a Ford
However, Have a buddy start the engine cold with you under the hood. My guess would be that you have a accessory making some noise. Was this one of those 5,000rpm for 500 ft burnouts? My buddies old 90 GT did some awesome ones.
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 11-02-2005, 02:24 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Sounds like you are using a Fram oil filter which is allowing the oil to drain back into the oil pan and therefore causing you dry starts.
What oil and filter do you use?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-02-2005, 02:48 PM
ya i bet thats the problem, my friend said the same thing...
what do you suggest?
Old 11-02-2005, 02:54 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Well i know they make AC Delco filters for it but i guess your not open to that.Maybe the Motorcraft filter at Wal-Mart or a Wix filter
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 11-02-2005, 03:29 PM
BlazerLT's Avatar
AF -Advisor
Motorcraft, Wix, Mobil1 are all good oil filters.
Hopefully you are using the proper 5w30 or 10w30 for your car.
Old 11-02-2005, 03:38 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Re: Guy's I know this is the Blazer forum, but you guys know what your talking a
That was the first thing that came to mind, while I was reading it.
Gotta love FRAM!
Old 11-02-2005, 07:12 PM
trypodd's Avatar
trypodd trypodd is offline
i have owned few fords and i may be wrong but figured id sugest the starter. on fords thay use a gear that disingages when the engen reaches a certen rpm that gear may be hanging up a bit on cold starts the burnout may be a coencidenc.[sorry cant spell]. this is just a sugestion but i thought id through it out their.
Old 11-03-2005, 08:54 AM
thanks man, that sounds like a possibility too, but it sounds like its coming from the inside of the back of the engine near the fire wall
Old 11-04-2005, 12:46 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Guy's I know this is the Blazer forum, but you guys know what your talking about...
What oil and filter are you using?
Old 11-04-2005, 12:29 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
That clanking is no oil/oil pressure in your engine. It takes a couple of seconds for oil to get through the engine. Like everyone said, what oil filter are you using, and what oil are you using...?
Old 11-04-2005, 01:34 PM
haha, ok let me check my last oil change...
Old 11-04-2005, 01:36 PM
ok...
Looking at the bill, they put in Valvoline 5W30 (VA5W30B)and a Valvoline Oil Filter (V047)...
Mean anything to anyone?
Old 11-04-2005, 03:43 PM
trypodd's Avatar
possable starter bind
if it is your starter the sound may come from near the fire wall the problum with ths is when you did your burnout you may have shifted your engine and transmishion slitly causing the starter to bind slitly on the flywheel if this is the case i would check the bellhousing bolts to make shure thay are touqad to specks if thay arnt thin you may have a real problum i have had this happen before on a different car was your transmithion replaced resently. if it were a dodge or chevy i would sugest a missing shim unfoutunatly ford at least the ones i owned dident use shimes if you decide to check the bell housing i would check the bolt holes for egg shaping but if its only shifted once that may not be a problum relining the engine and trans and re toqing the bolts should fix the problum.
Old 11-04-2005, 06:19 PM
blazes9395's Avatar
Newbie mod
Another question, has the car been doing this recently(like last oil change), or has it been doing it longer than that?
