Old 11-02-2005, 10:09 AM
4G63t Power 4G63t Power is offline
quick question about cd player
I just recently bought a 93 LX Hatchback 5.0, and it came with the stock deck. The first thing I wanted to do was get rid of that, so I went to a local vendor and bought a wiring kit to hook up my cd player. Sure enough, even though it said "made for ford 85-2004" or whatever, the connectors were different. I took it back down there and all he said was "Ford is really weird, sometimes these wiring kits don't hook up, in that case, you have to hard wire it to the existing wires, and run your own speaker wires to the speakers." Is this true? Is it really that hard to hook up a cd player in my mustang?
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 11-02-2005, 12:05 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: quick question about cd player
Just wire it up, the speaker wire are already ran, all you have to do is ohm them out, if you do not have a multimeter, you can use a AA battery on the wires, to find out which speaker goes to which wire. When the battery is hooked up, the speaker with produce a hum.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 11-02-2005, 12:12 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
I want to be able to hook the stock deck up at some point, say when I sell it. Are there any available harnesses? I don't wanna go cuttin into all that stuff.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 11-04-2005, 02:00 PM
dorfboy dorfboy is offline
Send a message via ICQ to dorfboy Send a message via Yahoo to dorfboy
Woah hold up.
93's are a bit different. I think they came stock with a premium sound system.
There is an amp hooked up to them and you have to bypass it to get to the speakers. So you could easily do that, but you will have to run three wires for the main part. They come off your CD player as followed.
Red - accessory.....turns on when your ignition turns on and off as well. Wire to like an open fuse slot or find one off the radio's existing wiring.
Yellow - main power wire, it keeps the power constant to the radio so that it will keep your presets and everything stored in. Must hook up to a constant power source, make sure there is a fusible link in there. (ex....lighter or something for the car.)
Black - black of course is our ground wire.
If I am correct some of the plugs should be the same atleast to the power side of it. The one that its different should be for the speakers and that is where your trouble begins, becuase it goes into the amp. I disconnected them at the plug into the speakers and then ran my own wire. This way all I had to do was plug them back up and then put the stock deck back in when I wanted to.
