Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-02-2005, 08:53 AM
Killa's Avatar
Killa Killa is offline
is this normal ?
I just install cold air intake ( take out my eclipse, cant believe it fix ) to my cousin car ( 99 civic dx ), and the check engine light on. Is this normal, how do I fix this ?.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 11-02-2005, 11:31 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: is this normal ?
the CEL is probably due to a sensor that you didn't plug in....maybe a mass airflow sensor, air temp sensor or whatever that little sensor is in the intake pipe on Civics.....be sure to hook up the PCV too!
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-02-2005, 12:19 PM
Killa's Avatar
my intake dont have pvc , can I just buy the breather and put in on the pcv ?.
GM FOR LIFE !!
95 camaro lt1
Old 11-02-2005, 01:40 PM
Schister66's Avatar
AF -Advisor
i dont see why not, but where did you put the little sensor that goes in the intake??? That's probably what's causing the CEL......
Old 11-02-2005, 02:48 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
in any case, pulling the cel is necessary for any time the light comes on.
http://www.honda-tech.com/zerothread?id=1171263
more than likely, it is just the IAT sensor. is the IAT sensor hooked up anywhere. if there is no location for the iat sensor, just make drill a hole big enough on the intake to stick the grommet section of the iat in, so it can fit snugly and tight.
also, the pcv valve is not located on the intake. its on the breather chamber.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-02-2005, 06:14 PM
Killa's Avatar
ok I just bought the little breather filter, and i put that on the tube that come out from the valve cover, and the IAT sensor , i just leave it alone, is that ok ?.
GM FOR LIFE !!
95 camaro lt1
Old 11-02-2005, 06:44 PM
AF - Advisor
plug the iat sensor in the intake. when you smog, replug the line back into the valve cover and intake.
Old 11-02-2005, 08:22 PM
Killa's Avatar
how do i plug iat sensor in the intake ? , my cold air intake pipe. Is just a long tube no hole coming out of it to plug anything in, unless I drill the hole for it . Is is bad to leave the iat sensor unplug, how bad what is ?. and what it do by the way ( control air ? ).
GM FOR LIFE !!
95 camaro lt1
Old 11-02-2005, 09:48 PM
AF - Advisor
the iat is a minimal sensor used by the ecu in within the fuel system. nevertheless, it is important, unless you dont care about your gas mileage, drill the hole and plug it in.
Old 11-02-2005, 10:33 PM
Schister66's Avatar
AF -Advisor
IAT.....air temp sensor??
Old 11-05-2005, 09:24 AM
machcivic machcivic is offline
It seems obvious what you should do. Get a new intake and follow the instructions. It doesn't have to be that hard.
