Old 11-02-2005, 06:26 AM
kingsblend kingsblend is offline
Post how can i make my car very powerful and fast
i have a 89 z28 camaro and i wanna make it very fast and very powerful can anyone tell me what i should do it has a 350 v8 and the tranny is auto with overdrive thats all i know so far
Old 11-02-2005, 07:51 AM
MrPbody MrPbody is offline
AF -Advisor
Re: how can i make my car very powerful and fast
Well, the sky is the limit... That is, 350 Chevy responds to modifications very well. Tons of goodies out there for it, as well.
Start by defining as clearly as you can, what your performance goals are. Next, establish a budget. The budget must be realistic, both from an ability to maintain it and the goals. You can't get 500 horsepower for $400...
Decide whether or not to build the engine currently in the car, or pick up another "core" and build that. With some minor variances, a 350 Chevy is a 350 Chevy. Your '89 uses the "late model" 1-piece rear main seal. It's easier to use that configuration than change everything over to the earlier versions.
A 4-bolt main block is desired for performance. You should consider a "stroker" (383) to achieve the most "bang for the buck". That may require upgrades to the injection system to feed the larger engine. The computer will also need upgrading, HyperTech and others make the "chip" for the changes.
The drivetrain will need to be upgraded to take the increase in power. The transmsiion should have a performance rebuild including a "stage 2" shift kit (if automatic). The rear axle may become the weak link in the chain.
Define your goals and approximate budget and we can get specific!
Jim
Old 12-20-2005, 04:11 AM
CivicSlayr's Avatar
CivicSlayr CivicSlayr is offline
Send a message via AIM to CivicSlayr
Budget is the key, if your rich (which i assume your not, due to the car choice) go 1471 blown injected on alky, fiberglass body, tube frame.
For a mild street build, headers, shift kit, intake, cam, rockers, exhaust, carb, flex lite fan.
"This cop was on my ass, but then i hit my overdrive button and i was gone... swear to god."-Mike Miller
Civicslayr don't post much, but when he does post youd better read it or he'll come over to your house and pimp slap you. -Slammed2themax
A must read: The Bathroom Strory
A must visit: Fecklessthings
Old 12-22-2005, 11:26 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
you could also get a supercharger, it will give it alot more power and alot of torque. the 350 is the most commonly used engine, so there's alot of parts for it and they're fairly cheap. start off with the breathing, intake and exhaust, then go with the tranny, then go stroker kit and/or blower.
With the whole intake and exhaust system installed you should notice a good ammount of added power.
