Old 11-02-2005, 04:49 AM
ingerbob ingerbob is offline
Send a message via AIM to ingerbob Send a message via Yahoo to ingerbob
Question quit running while driving
I have a 99 Dadge Caravan w/2.4 L . I was dirving to work and it just stopped running. There was no noise. All gages's and lights still work. It also still turns over but it acts like either ther is no spark or the fuel has been cut off. Any Suggestions?
Old 11-02-2005, 05:52 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: quit running while driving
Yes, check to make sure the cam is rotating when turning the engine over. You should be able to see this by looking in the oil fill hole on the valve cover. If not the timing belt has broken. Second, if the belt is in good shape you will probably need to change the crank position sensor as it has probably failed. If you are getting spark then check the fuel. Spray a little starting fluid in the throttle body opening. If it starts then the fuel pump is bad. If not try the CPS.
Welcome to AF!
Old 11-20-2005, 01:10 PM
rrichard7 rrichard7 is offline
I'm sure this is to late. How about the ASD fuse. I had one go on a 96 T&C. It is labelled "Engine" under the hood in box near battery. It is 25 Amp.
