size availability?
what are the available engine sizes that would fit in a 65 convertible? and what would be the best one to use if im lookin for a decent balance between performance and show status? im not overly concerned with having a lot of power. maybe something that could be modded to keep up with my friends 79 camaro 350. but not a neccessity. lol. thanx
Re: size availability?
I believe that in 65 they didn't get any bigger than a 289. I'll find out when I get to my Chiltons though. A little mustang like that wouldn't really take much to get it moving. But if you wanted to go big there are lots of options. Such as 429's 428's 427's. Those might be a little hard to find and would take some modifications. Maybe a 302 which has many mods out there or a 351. If you really wanted to you give a 289 a little something.
I'd go with a 302, there is not much room in a 65 engine bay.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Re: Re: size availability?
Like mentioned, the 289 was the biggest engine those cars came with. But a 302 is basically the same size and will fit just the same. A 351 is a task but a 302 would just drop right in. Also you can find a 302 almost anywhere. They are very common.
1969 Cougar 357w & TKO - 475hp |
whats a mustang II IFS? again, not a neccessity, but which of these would compare to the chevy 350 my friend has?
A mustang II Independant Front Suspension will allow you to cut out your shock towers and allow you more room. That would be an option if you wanted to go with a big block or make a 351w or 351c swap easier.
To compare cubic inch wise to your friend's 350sbc I would suggest a 302 stroked out to a 347. That takes the 302's stock 4.000" bore out to 4.030" and the stock 302 stroke from 3.000" out to 3.400". That would put you close in cubic inches. After that we would need to know more about the chevy. Or atleast how much power it is making to be able to give you any more advice to make your 347 compare to the 350. Let us know you power goals or even your budget and we will try to guide you in the right direction.
