Old 11-02-2005, 01:14 AM
race_or_die race_or_die is offline
rearend?
what rearend would work best for a boost in my take off for a 3.8
Old 11-02-2005, 08:20 AM
tcfco2005 tcfco2005 is offline
Re: rearend?
change out the gears with some 3.73's
1991 RS
305 T.B.I.
700-R4
Old 11-02-2005, 08:54 AM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: rearend?
or find a 4th gen camaro rear that is out of a manual car.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 11-02-2005, 11:35 AM
KaotiKCamaro5's Avatar
KaotiKCamaro5 KaotiKCamaro5 is offline
Send a message via AIM to KaotiKCamaro5
Re: rearend?
honestly, i wouldnt go any higher than 3.42 gears in a 3.8.. if you go with 3.73's with a stock/slightly modded car, not only will your car feel like a 4 cylinder when it gets to 3rd gear, you'll have horrible gas mileage to boot...
"doing that is like trying to sell porn to a 6 year old..... It's just wrong" - hypsi87
LE123456712: i promise i will stop filling your email with my boobs
Kieft125: lol.. good, its starting to get rediculous..
Old 11-02-2005, 01:10 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: rearend?
Honestly Kaotik that is completely groundless and a myth that has been proved wrong some time ago now, with 3.8s at least.
With that said, if you can find a disk brake rear out of an LT1 that has 3.42 gears then you will be happy. You will get a much better gear ratio, will have an LSD (put power to both wheels instead of just one), and the better brakes. However, if you have the Y87 option you already have a LSD, and possibly 3.42s depending on transmission. Look in the drivers door for that RPO code also any that start with a G and let us know.
Gas milage wont change (mine slightly went up for city driving... think about it, your engine doesnt have to work as hard to get you those short distances. gas milage going down is mainly reported for highway driving where you hold a steady RPM, with 3.42s and 245/50/16 tires I'm at 2700-ish RPM at 80 MPH). Keep in mine that you will need to have your pcm recalibrated for the new gears so that your speedometer is correct (I went ahead and go ta full tune done while I was at it, made a nice difference). This can be done via tuning or with a speedometer reprogrammer that you splice into the wiring harness.
Post up any further questions.
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-02-2005, 04:56 PM
Re: rearend?
im just going on what i've been told.. personally my car has 3.23 gears and those are just fine by me.. i just feel that if a stock 3.8 can handle 3.73 gears, wouldnt they come stock or at least in a performance package for the v6? as far as gas mileage, i always attuned it as the bigger ratio gears need more power, meaning you'd have to accelerate more to get that power.. meaning you'd be using more gas... although.. im not exempt from being wrong...
Old 11-02-2005, 05:42 PM
Re: rearend?
the numbers i found were gvwr
1879 kg
4193 lb
and gawr rr
936 kg
2064 lb
Old 11-02-2005, 06:46 PM
R.OConnor R.OConnor is offline
Send a message via AIM to R.OConnor
Re: rearend?
the only issue is your carrier, you will need a new one. 3.8 camaros autos have series two carriers which are smaller and will only support up to a 3.08. If you wanna go bigger you will need the series three carrier. IF you have a manual then knock yourself with some 3.73s.
If you do have an auto, I would recommend finding a z28 that rear ended someone and buy the complete rear end (bango and all) intact and just bolt it on
SLP RAM/CAI
Whisper high flow lid
K&N panel air filter
Magnaflow catback
85 bhp dry shot NOS (0.045 jet)
Old 11-02-2005, 09:34 PM
Re: rearend?
thanks alot for the tip
Old 11-02-2005, 11:32 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Re: rearend?
I can't think of much of any car that comes stock with 3.73's
Old 11-03-2005, 02:14 AM
Re: rearend?
If a stock 5.7 could handle 4.10 gears, wouldnt they come stock or at least in a performance package for the v8?
and liek I explained, the better acceleration helps city milage cuz you dont need to use as much gas to get to say 40 mph... highway is where it hurts because your cruising RPMS are raised. It's not too drastic tho
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
