Old 11-01-2005, 09:55 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Oil on the left side the timming belt?
I was just wondering why the left side of the timing belt would have oil, not like on the top, but the side of it....... its only on one side 2.....
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 11-02-2005, 03:32 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Oil on the left side the timming belt?
Most likely a seal is leaking oil. It could be any one of these:
Valve cover seal
cracked valve cover
cam seals
crank seal
oil pump drive seal
front bshaft seal
bshaft tensioner bolt hole
cracked/loose/blown out gasket oil pump/front cover.
Any oil on the timing belt is bad. Check the most obvious places and post back your results.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
