Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-01-2005, 08:21 PM
raymarquise raymarquise is offline
95 Tsp stalling
I just got a 95 Transporter - When I put it in drive, the rpm drops to about 300 then goes back to idle, sometimes it stalls. At low drive speeds (below 40 Km/hr) when I try to accelerate ( or at a stop light and try to move) the engine starts to miss - ( it does not backfire). It misses a few times then runs OK. I only have this problem moving from a stop or at low speeds; at highway speeds everything is fine. Any help would be appreciated.
Old 11-02-2005, 07:38 AM
LMP's Avatar
LMP LMP is offline
Re: 95 Tsp stalling
First check the exhaust recirculation valve (EGR). One idea is to disconnect the plug that feeds it to see if it makes a difference..however if it is stuck in partly open position, it might not make a difference.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 11-02-2005, 07:02 PM
Re: Re: 95 Tsp stalling
Thanks. I switched the ERG valve with one from an engine my friend has in his garage - but it made no difference. The van has a new fuel pump; I also changed the throttle body with one from my friend; new plugs; switched IAC valve; switched MAF sensor (on the front of the engine). The CEL is not on or flashing - so I cannot get a code. Any additional help would be a bonus.
Old 11-03-2005, 07:39 AM
LMP's Avatar
LMP LMP is offline
Re: 95 Tsp stalling
ANy difference between starting from cold or when hot? I can provoke this problem on mine because I have tricked the coolant temperature sensor with a switcheable control and falsely sending high temp reading to computer when in fact the engine is cold does mimick your problem. But when the engine is actually warmed up, I cannot reproduce the condition...so just for a try, I'd suggest you DISCONNECT the temperature sender: this is equivalent to a low temp reading and will command for a richer fuel mixture...just see what it does. In addition to the AIR temperature sender, here are 2 ENGINE temperature senders: one for the gauge (1 wire) and 1 for the computer (2 wires): I 'll check for its exact location and come back with that info.
Old 11-03-2005, 08:34 PM
When I first start up in the morning or when the engine is cold, the problem is really bad - almost impossible to drive, but when the engine has warmed up (coolant temp is at normal operating temp), the miss is still noticeable, but not as bad. Should I disconnect the sensor on the air intake???
Thanks.
Old 11-03-2005, 10:01 PM
LMP's Avatar
LMP LMP is offline
Re: 95 Tsp stalling
THe coolant temperature sensor acts on mixture, but the air intake temp sensor impacts mostly on timing, not on mixture so I would not think it could be involved in your symptoms but giving it a try is no risk.
here are resistance readings for temperature sensors (air and coolant)
www.avigex.ca/xport/thermistor.jpg
Old 11-09-2005, 06:05 PM
I took the van to a mechanic, and after 2 days, he says: when the accelerator is pressed - somewhere from initial press to about a quarter way down, the MAF reading goes to zero. He tried a new MAF and ECM but it made no difference. This problem ONLY happens with the transmission engaged (in drive but I am not sure about reverse), there is no problem revving the engine in park. Is there a transmission sensor or connection that sends a signal directly to the MAF?? or indirectly through the ECM??
or if there is a short circuit happening, where would I begin to look???
The mechanic says the engine runs with the MAF disconnected - I am not sure if it just runs at idles or if it actually drives - can I drive it home from the mechanic with the MAF disconnected (20Km)???
Thanks.
Old 11-09-2005, 08:36 PM
LMP's Avatar
LMP LMP is offline
Re: 95 Tsp stalling
I'm not too sure what your mechanic means about the MAF reading going to zero..the MAF signal is kind of pulsed and is not directly readable with a voltmeter...
www.avigex.ca/xport/maftest1.jpg
www.avigex.ca/xport/maftest2.jpg
so unless he is equipped with a digital scanning system, I'm a little bit skeptical...if I count well, you have tried 3 MAF's......so I'd look for something else...although the symptoms DO ressemble the MAF issue, may be plugs, connectors.... and no, the transmission does not send codes to the MAF. confirm when you have changed the whole throttle body, you have had the TPS (throttle position sensor) changed too?..but this would not match the severe RPM dip you describe when going into "drive"... What you experience is a little puzzling....
DId someone check the fuel pressure at the fuel rail? Fuel supply is most of the time a suspect when it is not the culprit, but it may happen.....should be over 40 psi.
ANd BTW, did some one check for error codes? you said the CEL is not ON, but does it light up at the startup check?...and some codes do NOT light up the CEL..'95 is OBD2 and the diagnostic codes are quite elaborate. www.avigex.ca/xport/allpontiaccodes.txt
EDit: P.S.: As Timguili mentions in next post, this one may still be OBD1 but cannot be read from the CEL with the jumper in the diagnostic plug. THese codes from the '93 OBD1 : www.avigex.ca/xport/3800codes.jpg
Old 11-09-2005, 09:28 PM
timguyli timguyli is offline
Re: 95 Tsp stalling
I have a 95, and i am Obd1 Not 2. Half way through the model year I heard the switched over.
Old 11-10-2005, 02:23 PM
Got the van from the mechanic today. Drove it with the MAF sensor disconnected: the rpm fluctuates at idle ( both in park and drive); sometimes it stalls; and from a complete stop there is still hesitation when I gave it gas, but once the vehicle is moving - there are no more misses or hesitation, regardless of what speed I am driving at.
It is certainly driving better with the MAF disconnected.
I noticed my oil pressure is very low at idle - almost to the red line. At driving speeds it stays locked at 275 Kpa. Could oil pressure be factor??
Again the mechanic says the MAF reading goes to zero when the engine hesitates - resulting in a cut off of the fuel flow. However, the MAF signal is not missing for 4 or more continuous seconds to set a code - just briefly ( 1 sec or a fraction).
Once the old codes (from disconnecting sensors) were cleared, and the vehicle driven, no new codes appeared; fuel pressure is OK; new plugs;
I have noooo idea where to go from here........
Old 11-30-2005, 10:19 PM
I changed the spark plug wires, and BINGO!! the problems "ALMOST" disappeared. I only noticed a very very slight hesitation a few times. That was 2 weeks ago, but now the problem is back. Weird.
Old 12-01-2005, 02:22 AM
vesamaan vesamaan is offline
I had bad stalling problems with my -94 3,8. Changed spark plugs+wires, helped for a while. After that I checked all vacuum hoses, found one broken, replaced it but it didn't help. Finally I blocked the EGR valve with a piece of sheet metal: no more stalling or shaking. This i did two months ago and the engine has run perfectly after that.
Antti
Old 12-04-2005, 08:02 AM
Wolfman1505 Wolfman1505 is offline
Could it not be the same problem i had?
When i hooked my laptop to the car, the MAF (right upper corner) reading went to zero to and then he staled.
I had a almost broken wire the yellow one.
Maybe he has to. That explains why a new MAF dont make any differnts.
Old 12-04-2005, 09:03 AM
Did you just run a new wire from the MAF through the firewall to the ECM?? I would like to give it a try so any insight into how you did it would be a great help.
Old 12-04-2005, 09:19 AM
Re: 95 Tsp stalling
No, my wire broke close to the connector.
I have to repare it yet. But for now i have taped it.
I have to look for a new connector and put all three wires into the new connector.
I dont know where the ather end goes to, but its a good iedea to test with trhee new wires.
