Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 11-01-2005, 06:34 PM
GreenGeckoUSA's Avatar
GreenGeckoUSA GreenGeckoUSA is offline
car wouldn't start this AM
Hi all:
Hoping someone can help me (without making fun of me for knowing jack ****). I have a 98 lx with 186k miles (manual trans.) The last couple of weeks I've noticed that when I turn the key, the car "waits" a few seconds before starting. It's not the usual "below quarter tank and freezing outside" problem. There's no turning over or clicking...just silence for a couple of seconds and then it starts. So, this morning when I turned the key, it wouldn't start. All the dash lights came on, the radio came on, but the car just wouldn't start. The starter didn't click and there was no cranking. The best way to explain it is that the car acted as if the clutch wasn't engaged. (Like sometimes if you don't press the clutch down enough it won't start). Anyway, I came home for lunch and tried it - it started fine. Tried it again this evening and it wouldn't start. I know there's some kind of clutch safety switch...could this be the problem? The battery is fine and I have a full tank of gas. Any help would be appreciated.
Old 11-02-2005, 01:00 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: car wouldn't start this AM
how do you know the battery is fine? you checked it with a voltage meter. go to your car and leave the lights on for about 1 minute. does it dim or die?
check battery, alternator, and starter. including all wiring.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-02-2005, 07:46 AM
I had everything checked this weekend when I took it in for an oil change/winter check-up. I specifically asked them to check those things because of the symptoms I was having. Of course it didn't act up for them but they checked everything (no problems). Just to be on the safe side, I did the light test before I went to work. The lights stayed bright and the car even started afterwards. Of course, twenty minutes later when I wanted to leave, it wouldn't start. It's really frustrating!
Old 03-21-2006, 12:42 PM
dorysch1 dorysch1 is offline
it could be the starter or the clutch switch
Old 03-21-2006, 03:01 PM
bugmike bugmike is offline
it sounds like the battery is at fault. take it to a parts shop and ask them to check the 'cold cranking amps'. battery may show normal volts, but have low amps. this recently happened to my 97 civics original battery and new one fixed it right up.
mike
Old 03-24-2006, 12:13 PM
catsman72 catsman72 is offline
if it ever happens again call a friend and if then can come over rool your car out of the drive way. when in the street depress the clutch and put the car in first gear and tell your friend to start to push the car and when going about 3 mph pop the clutch and the car should start and if it dose not start try it a again. i promiss the car will start
Old 03-29-2006, 12:41 AM
topnoss topnoss is offline
change battery and check starter cause sometime started are loose. wow 186k mile .change clutch system might be problem
