Old 11-01-2005, 05:44 PM
LastOne LastOne is offline
Unhappy 4L60E P0751 Not the solenoid....Help????
98 Silverado started getting the Solenoid A stuck or performance code. Shifts out of 1st at 25-30, also seems not to stay on OD. I replaced both solenoids for 1-2 and 2-3. No help. No parts in the pan, clean for 25K miles since filter change. I did notice when I removed the solenoid closest to the rear of the tranny, a spring loaded plunger popped halfway out. The front solenoid did not. I am guessing this is due to the fact it was in park and valve body was shutting off flow to one or the other solenoid?? Any ideas, local shop wants around 1500 to rebuild it.
Old 11-01-2005, 06:59 PM
maxwedge maxwedge is offline
A990 racer
Re: 4L60E P0751 Not the solenoid....Help????
If scanned wit the full trans scanner, shifts can be commanded, solenoid operation can be confirmed, slippage and gear error noted, this is the way diagnose any problem like this, also make sure the main connector on the trans is clean and tight. This "plunger" that popped is probably the shift valve, I assume you got in back in right?
Old 11-01-2005, 08:02 PM
2000CAYukon 2000CAYukon is offline
I think the plunger is the TCC solenoid which can explain why it won't stay in OD. Not sure if it is related to the P0751 or not. Does it look like this? http://www.transmissionspecialty.com.../77942-01K.htm (this is just the snout)
//2000CAYukon
Old 11-01-2005, 08:22 PM
Yes, I never fully removed the valve plunger and it is in there.
It is not the tcc solenoid, it is on the other side of the tranny I think. These 2 I changed are next to each other.
Thanks for the replies so far.
Old 11-01-2005, 09:02 PM
Re: Re: 4L60E P0751 Not the solenoid....Help????
Sorry, I misread your post. Yes the the TCC solenoid is on the other side. I did find this on another forum http://forums.automotive.com/communi...ting-problems/
//2000CAYukon
Old 11-01-2005, 09:14 PM
Here is another post that points at the 2-4 band as the issue http://www.transbuilder.com/tour/4L60E.html#bcc:17111
//2000CAYukon
Old 11-01-2005, 11:10 PM
troy1 troy1 is offline
AF -Advisor
the 2 you changed where the shift sol. A & B the TCC sol. is up front held in with 2 10mm bolts you have the change the whole harness to repalce it. there is a spring behind the one that popped out
