Front-end Swap
Is it possible (not asking if it's feasable) to swap the entire front end of a 1G Integra over to the CRX? I was looking at one today and thought that it was sexy... Just a thought.
[edit] I meant, the 2g.... Oh well... [/edit]
"Short, sweet, and to the point" 1987 CRX Si - Project Si 'RexSi' 1996 Ford Thunderbird 4.6L V8 - Plastic Intake Manifold, FTL. 2004 Nissan Sentra, 1.8s - The "s" stands for smooth....... ? Last edited by Figori; 11-02-2005 at 06:53 PM. |
Re: Front-end Swap
yep should swap right over bro duh?
common sense! |
Re: Front-end Swap
nobody will answer uh....oh... is it not possible to do this
Re: Front-end Swap
Figori, If your edit was meant to state swap the 2G Integra front end over to a CRX the answer is NO. Nothing is compatible in this swap. When you mean front end did you mean the body parts or just the supension parts? As the 1G Integra suspension is a direct swap into the CRX. Mind you if you want to use the Integra hubs you better be swapping the engine and drive shafts over as well. A 2G Intrgra engine can be swapped into a CRX but you will need to modify the mounts. JS
If you need one of these send me a PM for details. Edmonton, AB Canada |
