Old 11-01-2005, 04:02 PM
whitenite whitenite is offline
fan problem
whenever i turn the fan knob all the way to the right (so where the air would come out by the front windshield vent), the a/c lights up whereas it shouldn't. So i assume its a bad circuit thing, not sure though, but wondering how to go about fixing that?
Old 11-01-2005, 08:32 PM
quake61's Avatar
quake61 quake61 is offline
Re: fan problem
ok with the info u suplied i understood that when u use the defrost
the a/c come on? if so
in some cavys this is normal because when u use the defrost in winter
the a/c kicks on to remove the moisture
checks ur owners manual or any haynes manual
that will tell u for sure if ur car should work that way
i also need the model and year to make sure and if is a cavy or sunfire
Old 11-01-2005, 10:02 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
that is exactly correct, your a/c is suppposed to come on with your defroster, im not sure about the 2.4 but with the 2.2 you can definetely feel it in the acceleration too
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-02-2005, 09:29 AM
Re: fan problem
Its a 1999 2.4 cav. And yes that might explain why it does that. thanx
