Old 11-01-2005, 03:46 PM
LOWMONTE817's Avatar
LOWMONTE817 LOWMONTE817 is offline
93 blazer vortec Hot start issues, rough idle, stalling
Hi, I have been having problems with my 93 s-10 blazer. I figured out what was wrong and I thought I would share it here for people having this problem. My truck would start fine when it was cold. After a few seconds it would start to have a rough idle going up and down in RPM's. After it was warm, it would want to die when I stopped and I had to keep on the gas to keep it running. If it stalled, it would not start for like and hour. I took it to a mechanic after I gave up on fixing it myself and it ended up being a temperature sensor. It was telling my computer that it was 140 degrees below zero and dumping way to much gas in. Just a little tidbit of info for everyone out there.
-Kevin
Old 11-01-2005, 05:08 PM
jsgold jsgold is offline
Thanks for the post!! I have a 93 doing the same thing. Have tried everything I could think of, get advice for, or guess at. So far everything has turned up as not being the problem. Will look into this. Did he use a scan tool on this? How much was the sensor?
I used to be indecisive, now I am not so sure.
Old 11-01-2005, 06:15 PM
Re: 93 blazer vortec Hot start issues, rough idle, stalling
I believe he used a scan tool to find this. The sensor was $20. I had to get another part that was $20 also. I think it was something that sent the temp to my gauge.
Old 11-01-2005, 10:34 PM
93LT 93LT is offline
Yes, on 93/94 models, the gauge temp unit is in the right head and the ECM temp unit is in fron of the intake manifold.
I had to replace my sending unit in the head to get my gauge to read again. I think I'm just going to go ahead and replace the other unit as well, they look nearly identical (different connectors), I figure if one went bad, the other is probably not far behind.
Old 11-01-2005, 10:45 PM
Mine actually starts right back up again, so not as bad as this one was. It seems to be heat related though, as it seems to have a weak idle after it warms up. Will check them out to see if I find any trouble there.
Old 11-02-2005, 08:11 AM
The last part of my tuneup cured my bobble at a warm idle, I finally got around to changing the plug wires. Just mentioning it.
Old 11-02-2005, 12:22 PM
Advance Auto only shows one temp sensor. Is the one for the ECM called something else or a dealer only item???
Old 11-02-2005, 01:32 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
My part shop down here call it a Temp Sensor for the ECM and a Temp Sender for the gauge.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-02-2005, 03:19 PM
I believe it is Temp sensor for the gauge, and coolant sensor for the ECM.
Old 11-02-2005, 06:35 PM
the other one might have been called the temperature sending unit.
