Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-01-2005, 03:35 PM
cameryfan92 cameryfan92 is offline
Possible Valve Damage
I just talked to a mechanic and he said that there could have been some valve damage when the timing belt broke. Is this true or even possible.
Old 11-01-2005, 05:26 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Possible Valve Damage
If it's the 4 cylinder 5SFE engine, then there should be no damage. It is a non-interference engine.
Mike
Old 11-01-2005, 06:23 PM
The engne is a 2200, 2.2 l. 4 cyl.
Old 11-01-2005, 08:53 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
No damage.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 11-03-2005, 07:46 AM
jmd445 jmd445 is offline
What if it were a 2000 Camry V-6?
Old 11-03-2005, 10:37 AM
Toysrme's Avatar
AF - Advisor
Cool
For v6's only the vvt-i 1mz-fe & 3mz-fe v6's are interference.
Old 11-03-2005, 10:50 AM
GSS123 GSS123 is offline
Toysrme, what V-6 type is normal for a 1994 Camray?
Old 11-03-2005, 10:55 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
non-vvt-i (standard cam) 1MZ-FE
I believe the vvt-i 1MZ-FE is only an interference engine when the engine is using the performance lobes. Under 4000 rpm (or whatever is the cut-in point), the engine is non-interference.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-03-2005, 10:59 AM
Thanks Brain, So this type of V-6 engine could have valve damage if there was a timing belt failure? Right?
I better check my daughter mileage and see if replacement of timing belt is due?
Old 11-03-2005, 11:07 AM
Brian R.'s Avatar
Resident Chemist
Re: Re: Possible Valve Damage
Edit: According to the Gates manual, all Camry V6 1998-present (both 1MZ-FE and 3MZ-FE) are interference engines.
http://www.gates.com/downloads/downl...older=brochure
Old 11-03-2005, 11:10 AM
Brian R.'s Avatar
Resident Chemist
No, the 1994 engine is non-interference - no worries
Old 11-04-2005, 10:01 PM
Toysrme's Avatar
AF - Advisor
Cool
VVT = Varriable Valve Timing.
VVT-i, or VVT-I = Varriable Valve Timing with Intelligence
VVTL-I = Varriable Valve Timing & Left with Intelligence
The VVT portions are nothing more than a special cam sprocket that when oil pressure send from an oil pressure solenoid hits the sprocket - it advancess 15* of cam angle (30* in relation to the camshaft). It's either one way or another
VVT-I is the exact same thing, but the ECU can pulse the oil pressure solenoid on & off to control how far advanced it can go. (Anywhere between 0-30*)
VVTL is the newest system.
it retains the VVT-I cam timing portion, while also including an extra set of lobs w' a rocker that works exactly like vtec.
A VVT-I engine that is interfference is always interfference. (So a 1mz-fe VVT-i BEAMS is always interfference.)
They only have one set of lobes.
Old 11-05-2005, 12:46 AM
Brian R.'s Avatar
Resident Chemist
Ah, OK. Thanks for the clarification...
Is the VVTL engine non-interference, interference, or both?
Old 11-05-2005, 02:25 AM
Toysrme's Avatar
AF - Advisor
Cool
Both so far.
