Old 11-01-2005, 03:35 PM
95 blazerFD's Avatar
95 blazerFD 95 blazerFD is offline
Exclamation Is my CPI going bad
I have a 95 S10 Blazer 4.3l CPI. I have a slighly rough ideal. Also when i am just starting to accerlerate (exspecially going up a hill) my truck shuders and i have to give it alot more gas to make it stop shudering. could this be my CPI going bad? please help me out guys, thanks.(exuse all the bad spelling)
Old 11-01-2005, 05:47 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Is my CPI going bad
Its possible. But before you go and replace your CPI, you should check a few other things.
1) Pull your EGR and make sure you don't have any carbon chunks that mite be blocking the plunger from moving freely. This could cause the symptoms your having.
2) Check your fuel line pressure to ensure that you have between 62 - 65psi with your ignition switch on. If not, then you probably have a bad fuel pump.
Click below for more info on CPI troubles:
http://www.automotiveforums.com/vbul...archid=1244460
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-01-2005, 06:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Ever done a tuneup?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-28-2005, 09:44 PM
scottb1 scottb1 is offline
I have a 94 jimmy w/ 4.3 vortec 183 k miles and also had the same rough running condition last summer, replaced the cpi, cleaned egr valve etc. This cured the problem..then out of nowhere friday eve the same probs returned only worse, very bad vibration @ any speed. Was about to repeat the above process then noticed the pink wire (there are 2, a pink & white) that run from distributor to ignition coil was chaffed and bare wire was actually rubbing on the bolt that locks down the distributor. Taped over the wire and this cured the vibration. I was entirley surprised it was something this minor. just my .02 hope this helps someone.
Old 11-28-2005, 10:47 PM
Cailen Cailen is offline
Definitely tune up time bro. Check LTs sticky thread for suggestions.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
