Old 11-01-2005, 01:50 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Can the cat ping? If so, I will kill it
My car's issue's with pinging are getting outta hand. I've just had the timing belt, distributor, alternater belt, valves adjustment and timing adjustment done and the damn thing still pings like hell. I've tried increasing the octane up to 91, it did nothing. I've put fuel injector cleaner in it, hasn't worked. But can the cat. do it. My mom's 93 camry had a problem a few years ago with pinging and it turned out it was her cat. All the stuff inside had came loose. Is it possible cause I'm having a hard time believing her on this? Other than what I've listed, what else could it be? Could it be a warped head or bend camshaft or something? I'm getting almost insane with this problem.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 11-01-2005, 02:06 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Can the cat ping? If so, I will kill it
Damn, well, unbolt your exhaust and see if that clears the pinging. If you can't tell and it doesn't help, then I'd say do a compression test, recheck the valves, and turn the stereo up louder.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 11-01-2005, 04:04 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Are you referring to the Honda tick. Every honda I have heard has a little tick to it. Also my cat rattles/buzzes, not really a ping. Try tightening your heat shield on your cat, thats what mine was.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 11-01-2005, 07:32 PM
Smoghog Smoghog is offline
A plugged up cat/exhaust will cause ping. The reason is backpressure. You can get air in but not out. You can check this with a compression guage. Remove the upstream O2 sensor and attach the guage. Should not be over 2 psi at 2000rpm. Do you also have no power in the upper rpm's?
Let us know
SH
Old 11-01-2005, 08:13 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
Re: Re: Can the cat ping? If so, I will kill it
oh yeah...lol gotta love that ticking, its amazing my new motor dosnt have a tick yet.
im with sh on this...let us know
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 11-02-2005, 03:22 AM
Shaguar47's Avatar
Let us know
SH
Actually, I never really had much power in the upper rpms. I have raced an 87 crx si before and kept up considering I got the base model, but I noticed that after about 3000 rpm's, it just doesn't pull much anymore. I'll see that when I get my muffler replaced this friday, if they can put a cat on there as well. I'll keep you guys informed on what happens afterward.
Also, right around when i first bought the car, I read stories of how the heat shielding around the cat mostly comes loose and rattles on most civic's. So I bought some tightners to put around them. Still are on there.
Old 11-02-2005, 07:40 AM
Yeah, the Honda tick... even the hearing impaired can tell. Also, I have a sort of whistle... comes from the pulleys I think when my idle is relaxed (loppy cam... hard to explain)...
2010 Honda CR-V EX
