Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-01-2005, 01:26 PM
kristi2 kristi2 is offline
code 1491
Hello I have a dodge ram 1500 02. My radio went out I lost power. My hood light is out and the power lockas are acting funny. The ac is working the fan is kicking on and off. It is out of warranty of course... Any have any info for me THANKS!!!
Old 11-01-2005, 08:07 PM
1thunder 1thunder is offline
Re: code 1491
check your 25 amp rad fan fuse for your fault code and check your IOD fuse for your radio if ok lift the fuse box under the hood and check for green corrosion on wires or connectors sounds like you have 2-3 problems
Old 11-02-2005, 04:54 AM
Re: Re: code 1491
I will check all those things thanks. A friend at Best buy ran us a hot wire to listen to music. I think if it was the computer alot more would be on the fritz. Where the obd reader goes underneath the dash that is dead 2. We used the ignition to get the code. Maybe all the rain we had corroded the wires the truck sits out alot. Ill reply more after i have these things checked.
