Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-01-2005, 01:16 PM
wilson05's Avatar
wilson05 wilson05 is offline
Send a message via ICQ to wilson05
motor swap!
anyone know how hard it would be to put a chevy 305 into a jeep yj?
any info on where to get a kit would be nice and if its available then common problems foound when doin that
Old 11-01-2005, 03:53 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Why do you want to put in a 305? That engine sucks
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
Old 11-01-2005, 04:58 PM
cc_Penguin cc_Penguin is offline
First place I'd point ya to is Advance Adapters.
I have to agree with Sux, if your gonna through the trouble of swapping an engine, why not go ahead with a 350? Unless ya just have a 305 lieing around.
Old 11-01-2005, 05:01 PM
Ray H Ray H is offline
You will need an aftermarket radiator to handle cooling, new motor mounts welded onto the frame, new exhaust, a different transmission (the one behind your 4 cyl just wont cut it for long and Im not sure theres an adaptor for the 4 cyl trannies), an adaptor (depending on what tranny you pick) for the transfer case, you may have to change the length of the front and rear driveshaft if the tranny you choose is much longer or shorter than the stock one, you may have to cut the floor for a new shifter, the stock D35 rearend will really be tested with the added HP of a V8 especially if you run larger tires and offroad it. Most of the time its just more cost effective to do a whole engine/tranny/t-case swap from a FWD pickup or something instead of messing with adaptors.
Old 11-01-2005, 07:26 PM
wilson05's Avatar
Re: motor swap!
yeah well mabye i shouldnt do that swap ... and what makes the 305 suck so bad and yes if your wondering ... i do have a 305 layin around haha .. i pulled it out of a van i used to have now i have nothing to do with it... thats why i was wondering
Old 11-02-2005, 09:03 AM
The performance gain wouldn't be the significant with a 305. It has a 2 bolt main and will add a ton of weight to your jeep. Besides with the price of gas these days, your better off with a 4 cyl. Supercharge your jeep! Check out Avenger superchargers
1995 Jeep Wrangler
4.5L stroked I-6
Jet Chip Stage 2
Jet Thermostat
