Old 11-01-2005, 12:43 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Torque specs
Hey, I would like to know the torque specs for the following items:
Flywheel to crankshaft bolts
pressure plate to flywheel
transmission housing to block
transmission case adapter
There's prolly more, but that's all I could think of for now,
Thanks in advance
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 11-01-2005, 03:38 PM
Mikelb's Avatar
Re: Torque specs
bump
Old 11-02-2005, 08:04 AM
Mikelb's Avatar
Re: Torque specs
Ne1 know any torque specs, any links with the specs?... I have found some other torque specs... I just don't know what the specs for these are... btw, it's a SOHC (91, 6-bolt)
Old 11-02-2005, 09:46 AM
TMD TMD is offline
Re: Torque specs
http://www.3sxperformance.com/faq/torque/index.asp
TMD
Old 11-02-2005, 09:51 AM
Mikelb's Avatar
Re: Torque specs
Flywheel to Crank
55 ft/lb
Clutch Pressure Plate to Flywheel
13 ft/lb
Covers those two... btw, I had seen them, just forgot a/b them... thx
Old 11-02-2005, 10:25 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Torque specs
the other 2 torque specs are meaningless. just make sure they're snug. of course you don't want the transmission case to rattle, so make it snug. not sure what the transmission adapter case is.
all in all, torque specs are only relevant when it comes to critical parts (such as transmission internals, clutch parts +flywheel+pp, engine internals, engine head bolts, just to name a few off the top of my head). the torque spec of 10 ft-lb for a plastic panel screw or 20 ft-lb for a headlight bolt is meaningless. just make sure its snug. if you have a torque wrench and you're an engineer who is OCD, then you can torque every single bolt to its individual spec. but let's just be practical here.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 11-02-2005, 02:31 PM
Mikelb's Avatar
Re: Torque specs
True that... I've just never done the transmission thing before... I'd rather be safe than sorry... Thx neway
Old 11-02-2005, 09:58 PM
Linebckr49's Avatar
Re: Torque specs
granted, fair enough. but i just did my transmission not but a month ago. and it running stronger than ever (with the LSD insert of course ). but there's nothing to worry about as to the torque spec of the housing bolts. its like the torque of a wheel lug: make it tight.
but the safe side is always the better side.
93 3000GT base
Old 11-02-2005, 11:58 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: Re: Torque specs
Originally Posted by Linebckr49
all in all, the torque spec of 10 ft-lb for a plastic panel screw or 20 ft-lb for a headlight bolt is meaningless. just make sure its snug. but let's just be practical here.
lets be practical
LMFAO!
Old 11-03-2005, 07:06 AM
Mikelb's Avatar
Re: Torque specs
True, thanks u guys...
