Old 11-01-2005, 01:26 PM
1ofaknd 1ofaknd is offline
Send a message via AIM to 1ofaknd
Exclamation 2002 4dr Yukon into 2 dr jimmy
Since GM decided to not produce the blazer or jimmy in this new body style, i decided to make my own!
Starting with a 4 door yukon denali as seen here...
I then disassembled everything
Old 11-01-2005, 01:27 PM
Re: 2002 4dr Yukon into 2 dr jimmy
After a little work using a Makita Grinder, the middle was cut out of the truck (dremels are for suckers!!) lmao j/k
Old 11-01-2005, 01:31 PM
To reattach the two halves, i used JB quick weld on the inside seam.
I also resized the interior tub to fit into the now much shorter body
Here you can see the "weld" i did on the inside..
Old 11-01-2005, 01:36 PM
first application of body filler to make everything flat again.
doing the body work is quite a task...this is the third time around...and it's getting close
Here is the completed chassis and interior parts, i may add some detailing to the interior still
Old 11-01-2005, 01:37 PM
A little primer helps to check your work.. just a little more sanding and fixing a few spots...
Old 11-01-2005, 01:38 PM
and that's it..the conversion is completed!!
the conversion is complete!
Put the parts back on to test fit the doors and stuff..make sure everything still lines up
Old 11-01-2005, 02:08 PM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
thats pretty sweet
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 11-01-2005, 03:38 PM
KrNJuN's Avatar
KrNJuN KrNJuN is offline
Great work with your conversion! What color are you planning to color your new Jimmy?
Old 11-01-2005, 03:48 PM
BJ3113's Avatar
BJ3113 BJ3113 is offline
Thats Awesome I love it
Old 11-01-2005, 08:00 PM
Re: Re: 2002 4dr Yukon into 2 dr jimmy
Thanks. This is the first diecast i've ever really done.
I will be painting it candy lime probably...
Old 11-01-2005, 08:44 PM
Gafoto's Avatar
Gafoto Gafoto is offline
Send a message via AIM to Gafoto Send a message via MSN to Gafoto
Re: Re: Re: 2002 4dr Yukon into 2 dr jimmy
Personally I hate jimmies but I have to admit you did a damn fine job. Hope you get some nice paint on there.
Old 11-01-2005, 08:54 PM
Re: Re: Re: Re: 2002 4dr Yukon into 2 dr jimmy
well..they never made the jimmy in this body style..so what the hell huh? lol.
this body was headed for the garbage bin anyway..so i figured i'd play with it first
Old 11-01-2005, 11:54 PM
SolidSnake2634 SolidSnake2634 is offline
Send a message via AIM to SolidSnake2634
that's cool. what scale is it?
Old 11-02-2005, 07:49 AM
1/18th scale
Old 11-02-2005, 11:16 PM
nosliw2004's Avatar
nosliw2004 nosliw2004 is offline
Send a message via AIM to nosliw2004 Send a message via Yahoo to nosliw2004
dude that is so sweet!
