| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
lumina z34 engine switch but no spark
I got a lumina z34 from a guy my dad knows but the motor was shot. I replaced the motor and we get no spark. I got a new computer and the was not the problem i think it is the cam sensor but i cant find it. i did hear the motor i bought run so i know its good.
can anyome help me with this problem??? |
#2 | |
Re: lumina z34 engine switch but no spark
i changed coil pack to and i still dont have any spark.
#3 | |
Lactose the Intolerant
![]() Join Date: Aug 2004
Probe the leads where the position sensor(s) feed a signal back to the ICM, see if there is a pulse, or check with a test light to see if the injectors are pulsing.
Might help tell you if signalling is the problem, or if something else is happening. Got all wiring accounted for I guess? Nothing got pinched or stretched? Fuseable links (if any) good? Fuses? Threaten it with a big hammer? :0
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
#4 | ||
Re: Re: lumina z34 engine switch but no spark
I do not have the cam sensor pluged in because i cant find where it is to plug it in. I also am not sure what wire it is because 2 of them are the same plugs and the same color. One goes by the half shaft and one is just hanging there. |
#5 | |
Make sure the one by the shaft isn't supposed to go to a crank sensor right by the crank pulley, I honestly never looked at one of those engines long enough to notice much...does it have a cam AND crank sensor?
I think it will run with the cam sensor disabled, but not without crank sensor signal.
#6 | |
Home
On your 1993 CHEVROLET LUMINA-SEDAN/COUPE, the CAMSHAFT POSITION SENSOR is:UNDER HOOD, PASSENGER SIDE, UPPER ENGINE AREA, BETWEEN CYLINDER HEADS, MOUNTED BEHIND THE POWER STEERING PUMP RESERVOIR.
#7 | |
Home
On your 1993 CHEVROLET LUMINA-SEDAN/COUPE, the CRANKSHAFT POSITION SENSOR is:UNDER H00D, PASSENGER SIDE, UPPER ENGINE AREA, REAR CORNER OF ENGINE, MOUNTED BELOW EXHAUST MANIFOLD Found on Autozone's site, I just picked 1993 as I don't think you stated your year....
#8 | ||
I got a 92 z34 |
#9 | |
Should be the same
#10 | |
Huh. double checked that...according to AZ, the '92 has no cam position sensor, and the crank sensor is behind the crank pulley like I said earlier.
If your donor was a '93 or later, that's the problem, it has a differnt engine control system than your car. You will need the ECM and maybe a harness from the donor car...
#11 | |
stupidity should hurt
The crank sensor on a 92 is in the back of the block, there is no 24x signal sensor (the one behind the balancer) in a 92 Z-34, or either Lumina V-6 for that matter, 3.1 or 3.4. IF the donor engine is a 93, they have both crank sensors (in the back of the block and behind the balancer), and like Jeffco said, you'll need the harness and ECM from the engine donor car to make the swap work. THe 93 3.1 also has a cam sensor, where the 3.4X dosen't(it's a DOHC engine).
#12 | ||
I got motor out of a 91 z34 |
#13 | ||
Re: Re: Re: lumina z34 engine switch but no spark
do u guys have any picture where the cam and crank sensors might be it would really help thanks |
