Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 11-01-2005, 12:07 PM
higz7 higz7 is offline
99 corolla acceleration problems
When you accelerate in my 99 corolla it sometimes drops speed before it accelerates especially at about 63mph. it has about 83k on it. you could say it even stalls for a sec and drops speed then accelerates. any help would be very appreciated. it seems like something with the fuel system maybe a fuel pump we just replaced the starter about 2k miles ago thanks for your time
Old 11-03-2005, 05:21 PM
brianneves brianneves is offline
Re: 99 corolla acceleration problems
kind of expensive, but it sounds to me like it is your throttle position sensor. if i were you i would go ahead and replace it before it goes out. just a guess from what you have told me though.
Old 11-04-2005, 10:19 AM
peter i's Avatar
peter i peter i is offline
Send a message via AIM to peter i
Might be the Injector & sensor need check up & service ....(including feul filter)
I use soft99 or STP product "octane booster & cleaner ..." (Always works for me )
Love street mod & Super GT cars ? Click the ((tachometer)) to check it out!!!
Old 11-04-2005, 11:17 AM
johnholl johnholl is offline
63 mph is pretty fast for the Corolla....It's probibly protesting.
All kidding aside, It's a pot. I would first clean the TPS before spending the money to replace it. And use a cleaner that is safe for plastic components, or you'll damage it.
Old 11-05-2005, 09:58 AM
peter i's Avatar
I did 100 mph with mine AE92.
Old 11-09-2005, 03:55 PM
[quote=johnholl]63 mph is pretty fast for the Corolla....It's probibly protesting.
Where is the throttle positon sensor and how do i clean it? Thanks for all the responses.
Old 11-11-2005, 05:56 PM
im not sure of the exact location on your model but if you look at the throttle body, (thats the flapper that opens and closes to change engine speed) it should be on the opposite side of the throttle cable. remove the cover to it and spray it out with ELECTRONIC PARTS CLEANER. dont use brake clean or carb cleaner. this can damage it. if that doesnt fix it then you should probably replace it
Old 11-16-2005, 02:54 PM
Re: Re: 99 corolla acceleration problems
I gave it a tune-up and it hasn't studdered yet. In over a week.
Old 11-17-2005, 09:39 AM
peter i's Avatar
YOur fuel line need a "Clean up"
2. The air filter ....
3. The Exsauht system ....
4. The plug cable , plug etc
Old 11-21-2005, 11:45 AM
Put in new fram air filter fuel system cleaner in tank and of coarse the tune up last week everything is working great thanks again.
