Go Back   Automotive Forums Car Chat > GMC > Commercial Trucks
Old 11-01-2005, 12:13 PM
Jenstar Jenstar is offline
Question fuel in oil pan?
i was wondering if you could help me out...this is my first time on this forum...i have a 1989 GMC 2500 4x4 pick up with a 305...and my problem is that we are finding fuel in the oil pan...and we can't seem to figure out why this is happening...does anyone here have any ideas on what we should look for to figure this out...any suggestions you have would be greatly appreciated...i need help with this as soon as possbile as this is our plow truck and with winter on it's way we'd like to get this figured out soon
Thanks a bunch
Jen
Old 11-01-2005, 09:07 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: fuel in oil pan?
Is this EFI or a carb.
If its a carb, is there a fuel pump on the engine block? Thses things can leak internally straight into the crankcase.
If its EFI, you should have a throttle body EFI, where the only way fuel can get in the block is with a combination of leaky piston rings, a misfire and/or an excessively rich mixture (as caused by a bad O2 sensor or similar problem.
Old 02-17-2006, 09:35 PM
03CavyMan 03CavyMan is offline
Send a message via AIM to 03CavyMan Send a message via MSN to 03CavyMan
MagicRat has it right on the money. But it could also be caused by a faulty PCV valve. (Positive Crankcase Ventilation). The PCV valve is supposed to take all blow by gasses that gets past your rings and gets into the crankase, back into your intake to be reburned. If the valve is plugged, it will not be able to do this, and may cause fuel unburned gasses to be in your crankcase (oil pan).
2000 Chevrolet Silverado Regular Cab Short Box
4.3L Vortec - 5 speed
Ion Alloy 16x8" chrome wheels
Magnaflow Catback Exhaust
K&N Intake, Throttle Body Spacer
GM Automotive Technician
Previously - 2003 Chevrolet Cavalier
