Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 11-01-2005, 11:13 AM
thor3400 thor3400 is offline
97 Dakota wont start
I have a 1997 Dakota with the 5.2L (318) in it. The other day i had to change the battery and now the truck wont start unless the gas pedal is pushed down all the way. When it does start it has lost alot of power and once I take my foot off the gas pedal it dies. I haven't checked the spark on it yet but i can hear the fuel pump humm when i start it. Any insightful tips would be of great help.
Old 11-07-2005, 10:47 AM
fasstdak's Avatar
fasstdak fasstdak is offline
Send a message via Yahoo to fasstdak
With the pedal pushed down to start...it's acting like it's in a "Flood Mode" start. What's the voltage on the TPS with the Key ON/Engine OFF?
Is the "Check Engine" light on by any chance?
Chrysler/Dodge Certified Technician
1997 Dodge Dakota SLT - V6/5spd CC
Carillo Rods, KeithBlack Pistons (10.75:1), Ported & CC'd Heads, Crane Rockers (1.7:1), CompCams custom camshaft, Mopar Drive Gear, Smith Brothers Pushrods (7.050"), Ported Factory Intake, APS 50mm TB, APEXi SAFC-II Controller, JBA Headers, Magnaflow "TurboXL" Muffler, Cloyes True-Roller/Dbl-Row Chain with tensioner, etc. Dyno Proven: 214RWHP/238RWTQ (Without the Nitrous)
http://www.dodgetrucks.org/fasstdak
Old 05-12-2007, 09:26 PM
pieron1234 pieron1234 is offline
Re: 97 Dakota wont start
I bet it is the sensor in ur idle motor because i just had that and thats what fixed mine it is about a 100 dollor part
1997 dodge dakota 3.9L bored 30 over dome pistons, 2 and a half inch throddle body space, ram air intake, jba headers . no cat, dynomax muffler, and a phase 2 jet chip, body lowered 3 inches with a dodge dakota rt body kit
Old 09-23-2007, 10:25 PM
davida6302 davida6302 is offline
I have had this same problem and this has been addressed on this forum. It appears that the corelation between the discharging of the battery and the carburetor problems are related. I did what was suggested, and that was to spray carb cleaner around the outside and inside while accelerating to keep it running. At the worse it would be the idle control thats at issue, the problem I saw was the buildup of carbon in the throat of the carb, clean that away and the problem was taken care of. Try this a can of cleaned is like $3 bucks, thats a cheap fix compared to a shop to "rebuild" the carb, goforit.
