Old 11-01-2005, 10:57 AM
dieselbalvenie dieselbalvenie is offline
93 Grand Am fuse problem
Last night my sister dropped a penny in the cigarette lighter and it blew the fuse to the power locks and cigarette lighter...
Its a 93 grand am 2door and I don't have the manual to tell me which fuse is which. I checked the fuse box and wasn't sure which ones/one to replace. I have searched this forum religiously to find it but to no avail so if someone has any idea of what the label would be in the fuse box that would be a great help
Old 11-01-2005, 03:10 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: 93 Grand Am fuse problem
Welcome to the forum. If I'm not mistaken; it should be the "accesories" fuse or something to the extent. I would replace anything related to "accesories" or "dash" and you should get it.
Old 11-01-2005, 09:20 PM
swalt's Avatar
swalt swalt is offline
Is there any other symptoms? By chance do your interior lights stay on or the door chime continue to chime?
You may have shorted out your chime module. Been there, done that.
http://www.automotiveforums.com/vbul...t=chime+module
Old 11-02-2005, 07:17 AM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
It should be the power lock fuse, fuse box is located on the drivers side of the dash, its a 5 amp fuse I believe. I've done the same thing, thats why I have a splitter on the lighter and I mounted it so change can't get into it.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 11-02-2005, 12:57 PM
thats a good idea skinbum thx for the idea... however, I still can't find anything that resemble a pwr lck or accessorie fuse. I just wish someone knew the exact labeling or could look it up for me
Old 11-02-2005, 01:31 PM
It should be the 2nd fuse in from the right side on the top row of fuses, its a 15amp fuse labled ctsy, its next to the airbag fuse.
Yup, I own the suv.
Old 11-02-2005, 02:35 PM
gmack221's Avatar
gmack221 gmack221 is offline
Re: Re: 93 Grand Am fuse problem
If im not mistaken ctsy stands for curtosity lights, or something along those lines, if that isn't it take an ohm meter and check the resistance between the poles of the fuses (while installed with the key off) until you find the bad one, never know when you might find one burnt out that you forgot didn't work.
Old 11-02-2005, 07:01 PM
that was it... ctsy ... thank you very much
